Home > Td5 > Max Revvs, Tuning and BHP limitations.
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Having a little look around at tuned Td5s on youtube, and having a quick think on the way into work today whilst doing 3100 RPM on the motorway and thinking...
Whats the rev limit on td5, both Physical, and as far as you would reasonably take it?
I did 3500 once and boy i don't think i'd do that again...
But then having a look at the specs of a 15p in a defender it does the full 122Hp at 4850 RPM.
Surely can't be safe...
What it the main limiting factor in the td5 engine? why have we never really got above #210 Hp and even then unreliably...
Is it a materials thing where the block, pistons an rods can't handle this? it is a matter of stroke length? air induction?
All the above?
Just curious, seeing as how much HP can be achieved from just A map and curious to know the TD5s limits. I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #812144 27th Jan 2020 10:50am
bankz5152
4850 is the limit. Ive sat on the limit a few times doing hill climbs in sand.
250bhp is possible with a big VNT (and the rest) + uprated head studs.
Above roughly 2 bar boost the head can start to lift hence needing stronger studs.
Some have claimed 280bhp but im very suspect of that.
Post #812153 27th Jan 2020 11:39am
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
Slightly left-field thoughts and musings:
It's perfectly safe at 3500. The engine is very capable of running at high revs all day long, but the driver is less so capable because of the noise vibration and harshness. The better insulated Td5 in a D2 bears testament to this.
Have you experienced a Wright Off Road acoustic mat or similar? On recommendation I put one in my Td5 and found it to be cheapest way of accessing the power in a Defender without discomfort. JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #812157 27th Jan 2020 12:12pm
OsloBlue
I'm not actually interested in actually upping my power (for the moment) but just curious. Still interested in the matt though will give it a look thanks. I'm on IG: https://www.instagram.com/osloblue42/
Post #812159 27th Jan 2020 12:48pm
bankz5152
Loads can be done in terms of soundproofing.
Mines lizardskined throughout, foam on top, rubber and carpet as the finish where possible. Happily sits at 70/80 without going deaf.
Post #812162 27th Jan 2020 1:25pm
jst
we used to run one around 200bhp and that worked well with a bit of reliability in it, much more than that and things go bang quick in my experience. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #812163 27th Jan 2020 1:50pm
roel
Mine does regularly his max revs, I know it is above 4500 rpm but most off the time I am not looking at the rev counter on moments like that. Like here:
 Roel
2003 90 Td5 (2009-now)
Post #812226 27th Jan 2020 9:14pm
lightning
I’ve taken my 2005 TD5 110 to 4,000 rpm on occasions, and it seems fine at that speed in fact smoother than it is at 3,000 but there seems little benefit in going much past 3,000 in normal driving.
Unlike my Ferrari where the 3.4 litre V8 got into its stride at 6,000 and was happy to hit 9,000 rpm in the intermediate gears.
Slightly different vehicle though.
Post #812257 27th Jan 2020 11:09pm
miker
I'll happily wring mine out past 4000rpm once warmed up when I'm in a hurry, it makes a great noise too.
Post #812267 28th Jan 2020 12:19am
bankz5152
Very much so. Ive hit mac revvs in high, 1st, 2nd,3rd been high in 4th n 5th but no sure how high. Hit the limit in every gear in low.
That said TD5s make peak power sround 3000rpm
Post #812274 28th Jan 2020 7:08am
roel
I am not that interested in peak power more in peak torque. And if you need the torque better be aboe the peak torque rpm range. If you are above the peak torque rpm and your tyres areasking more torque the revs drop and you get more torque available, if you are below peak torque revs and your tyres are asking more torque it will stall.
So if in doubt, rev it out. Rolling with laughter
And yes without Cat and middle demper it is loud at 4000 + rpm on full power. Roel
Post #812285 28th Jan 2020 8:50am
lightning
I assume you are talking about off road driving and competition use.
If you regularly drive a Defender TD5 like that on the road it’s going to do about 15mpg and you’ll likely need a new transmission before long.
Post #812286 28th Jan 2020 9:04am
bankz5152
On and off road for me. Never broken a part on tarmac.
Few bits off road but that was down to poor driving on my part Laughing
Averages 25mpg and weighs 2.7t
Post #812306 28th Jan 2020 1:10pm
OsloBlue
I was thinking generally just for tuning.
Recent average was 25mpg
When I was doing m25 daily I averaged 32mpg by drafting artics at 50mph... I'm on IG: https://www.instagram.com/osloblue42/
Post #812322 28th Jan 2020 4:22pm
Roy5695
Alive have just put a post up regarding a TD5!
He’s hit over 250 BHP Shocked 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #812325 28th Jan 2020 4:42pm
