Home > Maintenance & Modifications > Finally given some time to the wire mess: weird behavior |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2109 |
Hi guys!
After several years to see the cable mess inside the battery box I "took the bull by the horns" and start to clean it and put all in order. Still working in progress the change is notable. A picture showing the setup. Click image to enlarge A new earth poit at the left, then the fuse box down, a distributor with all the cables and finally the relays for the roof main ligths, the rear roof ligth and some side ligths under the awning. Still several wires missing but looks a way better than previous. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge Last edited by Eduardo on 27th Jan 2020 10:10am. Edited 1 time in total |
24th Jan 2020 1:04am |
The diagram
Click image to enlarge Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
24th Jan 2020 1:06am |
Hey guys!
Finally today I finish the main part of the installation but still I have a weird problem. This is the main installation done Click image to enlarge Click image to enlarge The main problem is when I connect the (+) fuse of the Ham radio (TYT TH 9800) with the car key out, the instrument panel ligths up (similar when you turn the key to II). All other fuses are out and the Motorhome not connected. So, I isolate the Radio and found something that not convince me. With the system isolated, the Ham radio start inmediately showing 13.4 V in the battery and operates correctly. but, with the radio off, I read a voltage of ~9V in the negative (as show in the next diagram) Click image to enlarge Is that normal? or something is wrong with the radio? Probably this 9V are spread trough the earth point to the fridge/MH battery relays and then to the live with ignition cable feeding all the defender circuit as shown in the figure. If I put the Ham radio earth directly to the battery the problem dissapear but Im not sure if I´m drawing current from the battery. Any thoughts? Click image to enlarge Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
27th Jan 2020 5:07am |
