excossack Member Since: 22 Feb 2012 Location: North West Posts: 6027 ![]() ![]() ![]() |
Picked up (well removed with a drill) a pressed LR badge from the back of a 6 pot 109 that's going for scrap & the metal plate with instructions for engaging 4wd. Oh and a series 3 Haynes manual. 1999 Defender TD5 110
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
I believe that the "extra bracket mod" is only applicable to 2.2 models, not 2.4. |
My bad didn't pay attention to which engine OP had.
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1371 ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge Removed the wheels ready arrival of the new ones and collection of the KO2’s Can’t say I’m too sold on the look. |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1875 ![]() ![]() ![]() |
It's the 2.2 I have. Do you have a link to the mod as there's no additional supporting bracket fitted? 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Is your servo ok?
I must admit to lying in bed last night pondering the same thing, I've had it vary when doing a couple of short trips today and when I can escape from the other halfs obsession with all those little jobs she keeps putting my way when she is decorating plus if it stops raining then I will get out and look at the servo and especially the vacuum pump first. Thinking about the pump though as there have been some noises from that area |
![]() Click image to enlarge ![]() Click image to enlarge Struggling to find a thread with the actual recall notice in, but two part bracket which bolts to lower side of alternator is clearly visible in before and after photos above. Just check if you have it fitted. |
Thanks Supacat.
Definately dont have that bracket, its just hanging in between the two ends of the hose. 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
What I'm not sure about is whether this was just a retrospective mod to 2013/2014 models post production and whether ones like yours 2015 onwards had the mod fitted on the production line or whether it would have had a different fix?
I've just spoken to my contact at the main dealers and he's checked and there was no workshop notice given for vehicles in my VIN range, and there's definetly no bracket fitted, so perhaps they came up with an alternative hose shape? 2007 - Stornoway Grey 90 XS SW - Gone
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
http://new.lrcat.com/#!/1235/3525/3564/273
Looking at the catalogue the bracketry is suppose to be there from VIN EA448483 onwards anyway ![]() |
So somebody with a 2015 or 2016 vehicle needs to say whether they have the bracket or not?
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2285 ![]() ![]() ![]() |
I have a very late 65plate 90 H/T and as best as i can see with the shrouds and everything in place then it does have that bracket
Will get some time at some point and remove some of the plastic to confirm with a pic |
Nice pleasant update on my braking problem, the hard brake pedal with impaired braking efficiency. I did initially think master cylinder but was swayed more to a servo problem. Yesterday I got the five minutes needed to have a proper look, looked round the front of the servo unit for cracks at the mounting, nothing. The feed pipe into the servo looked pretty damned good so followed the pipe back to the pump that gets partly hidden under the acoustic cover and there is the T piece that feeds the EGR valve and the thing had fallen out of the rubber jont.
What a result, push the pipe back in and a new bit of tape round it and the jobs a good 'un ![]() |
