Home > Maintenance & Modifications > Wheel arch shelf?
HDshark
United Kingdom 2011 Defender 90 Puma 2.4 CSW Orkney Grey
Wheel arch shelf?
Hi folks, new to forum having just got my first defender Very Happy
Looking for ideas on levelling off the load space above arches in my puma 90?
Don't particularly want to fork out for a drawer system, and most would be too short for my needs, as I want to be able to store rifles underneath. Are there any options out there to buy just a board levelling off across wheel wells, maybe with a central support for strength? Idea is to have dog box sitting on top, with the underneath area for storage. I'm no fabricator, so pre-made is best!
Post #811983 26th Jan 2020 12:13am
Bluest
I did that. A couple of lengths of steel box across with marine ply over them. 2007 110 TDCi Station Wagon XS
Post #811984 26th Jan 2020 12:46am
Sulisuli
Hi if you feel you don’t have the skill set to make it, have a chat with a carpenter or kitchen fitter, ask for a list of timber etc he will need and let them make it for you Thumbs Up good luck. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #811997 26th Jan 2020 9:15am
Co1
Trailer board is probably most suitable, and if you can use a saw you should be able to do it yourself, or as suli says, get a joiner to cut it down. A big measurement though is the size of your rifle. My 26” barrelled X Bolt is no where near fitting lengthwise on the floor of my 90 and is mounted higher up. You might get away with something 20” ish.
If by any chance you travel to Yorkshire, I’d be more than happy to cut it down for you with the tracksaw.
Post #812000 26th Jan 2020 9:31am
deaallen
United Kingdom 2012 Defender 90 Puma 2.2 SW Santorini Black
This is what I did, 3 sections of I think they call it furniture board at homebase, then a section of L plate metal cut down and stuck to each end. Very easy to take in and out as needed.
It made the back a lot more practical for shopping etc and very strong, after putting the front seats down my girlfriend and I spend a night sleeping on top of it with an inflatable mattress with no problems!
I later covered it in automotive carpet so it didn't look so homemade but then put bench seats in the back so don't really use it much anymore. It also had the added benefit of deadening the sound coming from the back slightly.
Post #812003 26th Jan 2020 9:59am
Siwynne
I did it with a piece of ply and auto carpet. Plenty strong enough. It usually has a transk9 box sat on it.
Post #812007 26th Jan 2020 10:44am
Siwynne
Better pics.
Point to note. Dogs can get in and out when box sits on the floor. The old man needs help when it’s up higher.
The odd pics are details of how it is secured using roof hooks to load securing rings. I wanted to be able to remove it and leave no trace it was ever there.
Post #812008 26th Jan 2020 10:49am
Sulisuli
^ nice tidy job and with carpet fitted looks OEM Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #812009 26th Jan 2020 10:50am
Mdm
This is one a friend has done to his 90,
its all dynamat underneath as well.
home made side panels work well
not sure on the dark head liner and back door but its a fair bit of work and is a tidy job.
the drawer doesn't take a massive weight on its current rollers but does work well. the open side takes his camping chairs and bits.
its coming out on Monday as he has traded upto a 110 and will be making something new for that one/
Post #812019 26th Jan 2020 11:40am
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
some nice work their chaps! Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #812020 26th Jan 2020 11:46am
Siwynne
Another issue mine has thrown up is that heavy objects are now at tub side height. I am aware that if they slide and hit it they will dent the sides above the wheel tubs but below the body capping
Post #812045 26th Jan 2020 2:10pm
m3vert
Scotland 2011 Defender 110 2.5 TD PU Stornoway Grey
Anyone done anything similar on a 110 DCPU? I am looking for inspiration!
Post #812119 27th Jan 2020 6:02am
HDshark
Thanks everyone, there are some brilliant ideas there. Think I will give it a go myself after all!
Post #812160 27th Jan 2020 1:04pm
