Easier fix than sourcing and replacing a front brake hose at the test garage within the hour when it blew on the brake test just before Christmas
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6038 ![]() ![]() ![]() |
True! 1999 Defender TD5 110
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 480 ![]() ![]() |
Beautiful misty morning today, very calming.
![]() ![]() Click image to enlarge |
Neilios Member Since: 01 Nov 2017 Location: Co. Durham Posts: 170 ![]() ![]() ![]() |
Very nice and the best colour 😄 1997 110 Hi-Cap Keswick Green
1997 90 Truck Cab Blue 1996 Discovery Pickup |
Gravygraham Member Since: 15 Mar 2017 Location: East Kent Posts: 187 ![]() ![]() ![]() |
This is what I did in my Defender today.
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 ![]() ![]() ![]() |
That doesn’t look at all good , did you hit something or did it a component fail ?
The swivel seems to be totally detached from the axle casing https://www.instagram.com/hustynminepark/ |
Yup, the bolts on the flange on the end of the axle all sheared. Collision with a Focus. Lucky custodian of several Landies
Duplicated post - can’t delete it. Lucky custodian of several Landies
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1876 ![]() ![]() ![]() |
Sorted my boost issue. Hose had been rubbing on the steering knuckle
![]() ![]() Click image to enlarge 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21015 ![]() ![]() |
^^^^ This is the one Blackwolf on here warned people about and I checked mine, close but not an issue.
So it goes to show what can happen. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Put a 24" lightbar on the front of my 110 today to replace the 8" Wipac jobbies. Yes I'm impressed, it's one of those combined flood and spot light ones.
The downside is that when I went out tonight to do the things I have to do the damned brake pedal has gone hard with a very reduced braking efficiency. Points very much to the master cylinder, I only did the thing a couple of years ago, the brakes were absolutely fine this morning but not tonight ![]() |
Sadly it's the one I swapped 14 months ago for a BAS one chasing a previous boost leak. Nothing wrong with the product but very little in the way of clearance 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Mini Landie Member Since: 23 Sep 2015 Location: Basingstoke Massiff Posts: 159 ![]() ![]() ![]() |
Revisited a ford that I last went through in the summer that wasn't much of a ford at the time.
I'm pretty chuffed with that bow wave! |
Have you all got the additional bracket LR retro fitted to earlier ones? That is supposed to solve just this issue. |
