![]() | Home > Off Topic > Mending watches |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1910 ![]() ![]() |
Not sure if this will help much, but the O rings in diving kit (torches, computer batteries, inflator valves etc) is usually given a smear of silicon grease to help keep the water out. I assume watches would work on the same principle.
The only time I'm aware of any non-standard silicone grease being used is if the kit concerned is in Oxygen service, i.e. exposed to high concentrations of O2 - then an alternative is used. Can't see this being an issue with a watch. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 ![]() ![]() ![]() |
Sounds like that’s what it needs. Thanks
