![]() | Home > Technical > 2000 TD5 Diff Lock questions, have searched |
| topless_matt Member Since: 29 Mar 2015 Location: norfolk Posts: 68
First thing first..... does the diff lock actually engage?
Jack up one wheel drivers front is usually easiest with the diff lock not engaged, the wheel should spin freely. Now engage the difflock and spin the wheel, it should not turn, only a little bit until the slack in the driveline is take up. If it is as above then the difflock is working as it should. It is very u likely that the fork has seized internally as it is constantly lubricated when moving. Do you know to the best of your knowledge or did they say if the transmission had been out of the vehicle? Try the above and we can go from there. Hold my beer and watch this! |
| Bodyman Member Since: 19 Jan 2020 Location: North West Posts: 4
Hello mate thanks for the reply,
They didn’t mention the transmission ever being removed but obviously that doesn’t mean it hasn’t been. I have tried what you said, the diff lock doesn’t engage. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18047
Yes, unfortunately it is entirely possible for the internal parts of the difflock mechanism to seize, and since the selector fork is sprung against the actuating mechanism (it has to be this way) it is possible to have the situation whereby the linkage appears to work OK but nothing happens inside the box.
Unfortunately it is not easy to diagnose or fix with the transfer box in the vehicle. |
| OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825
When i bought mine was siezed in High range as that was where it had stayed for 40000 miles.
Had to take mine off and un jamm it. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
Took the tunnel out, took off the linkage for the diff lock and removed the actuating arm with the 3xm6 bolts , freed up the detent shaft inside and cleaned and greased all of the linkages to the lever.
We have working diff lock ! |
Glad it’s all working now. Sorry I did t reply to your previous response. Didn’t see it had a reply, good technology on iPads
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363
Glad it was nothing too serious and you got it sorted relatively easily
| All times are GMT |
