![]() | Home > My Defender > Our Galway Green Defender 90 |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Thanks!
You're right that Series III surrounds create the black bits but they're not quite a straight fit. It's necessary to cut the lips from the headlight surround apertures to provide clearance:
![]() Click image to enlarge You'll also need a couple of additional plastic nut inserts for each side: ![]() Click image to enlarge As you can see, the louvres between the sidelights and indicators conceal holes in the wing for the horn on TD5 and Puma models. Strangely, yours seems to be fitted with headlight surrounds from an earlier model as it should have the same louvres. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
sgreenham Member Since: 27 Apr 2019 Location: Southampton Posts: 145 ![]() ![]() ![]() |
Thats really helpful, thanks. So I'm thinking if I get something like these for left and right side and cut and spray them body colour...
https://www.johncraddockltd.co.uk/lr051110...phite.html Also where did you get the little white inserts from? I assume those extra two holes for the white inserts needed drilling? EDIT - I've now read your full write up about it on your thread Anorak which is great, thank you. |
Excellent
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
A little trip out today with a friend and his TD5 to Salisbury Plain. It's our first time green laning, we took it steady and had a great time. Also check out the cloud inversion in the third picture. It stayed like that all day
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11074 ![]() ![]() |
Nice pics and a great day for it
It fits!!!
Did it fit in naturally without any mods
Amazingly yes! It may be staying in the garage for a little while for various reasons and I was going to pump the tyres up before I moved it into the garage but I'm not convinced it'd fit if I had done that.
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
I don't suppose you know what size the small black fixing screws are that secure the light surrounds to the defender are do you Anorak? |
I used no.6 x 25mm stainless screws. Darren
Thank you
Not finished just yet and the whole Defender needs a damn good clean but I'm liking how it's evolving.
