Home > In Car Electronics > Where to Buy Original Wipac Crystals? |
They're two different but related things. Crystal headlights are indeed a straight swap improvement for the existing ones.
The uprated loom is designed to engineer out the poor design of the existing wiring that sees all of the power for the lights being drawn through the switch by introducing relays into the circuit. This not only prevents the switch burning out but can also deliver a higher voltage (the full, correct voltage) to the lights that can make them brighter. You can do one modification or the other without any issue. For best possible results though, do both together. I hope that helps. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
10th Jan 2020 9:13pm |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1829 |
I can agree wth all the replies which say that an upgraded loom, and direct wiring will make a big difference to light output.
Lonewolf - on your question about ease of installation, I'm not an electrical whizz, but it is pretty straightforward. I wouldn't take issue with the point about wiring back to the battery, but I didn't myself. I just took it from the back of the alternator and there have been no problems. Others are available, but I got mine from Landreiziger in Dordrecht/Netherlands and the quality was good, along with reasonable instructions. They have an option with ceramic H4 connectors for the headlamps, and it's just 'plug and play' - you connect it all up; plug in one of the existing/original headlight plugs into the new loom, and off you go. In a combination of that and the crystals I'd very subjectively say the light output was about 20% brighter than my original lights and wiring. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
11th Jan 2020 11:43am |
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 206 |
Cheers Donald thank you for the information, very helpful.......
NB I bet it’s a bit windy where you are today, take care. |
11th Jan 2020 12:42pm |
I’ve now been looking at the landreiziger loom which I like, €56.50, unfortunately I don’t have multilingual skills and therefore can only look at the photos and not read the Dutch blurb.
What I did notice was that there was also a picture of a switch, is that part of the loom kit? I also checked out the 90 second video which although brief was informative, but didn’t mention a new switch, perhaps it’s an extra? Any help appreciated. |
11th Jan 2020 1:16pm |
Ah. I think they must have changed their website a little, as I'm pretty sure there used to be a bit of English in there somewhere - or maybe a language tab top right. Doesn't seem to be there anymore, or perhaps it's because I'm looking at the site via an ipad which is bringing up a 'mobile device' version.
I would just cut and paste the text into 'google translate' - it'll give you the gist, or phone them during the week. Martin speaks pretty good English. When I got my loom, there was no additional headlight switch incuded. It's probably there to illustrate the point that the loom mod takes the full headlight current away from that switch, which is a known weak point. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
11th Jan 2020 5:40pm |
Cheers Donald, I was using an ipad too so maybe better checking on my laptop.
Thank you again for the feedback |
11th Jan 2020 6:31pm |
Update: I used my laptop and web translator and got the spiel in English: the loom is 40.5 euros or for 16 euros more you get a switch which is to replace a burnt out one if that was the case.
I also discovered what a winkelwagen is too...….its a shopping trolley.....you learn something everyday |
11th Jan 2020 6:52pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2055 |
Sure someone mentioned on here that the extra loom isn't required on the later Puma's due to how they have been re-wired??
Sure Martin or A.N Other could confirm?? |
11th Jan 2020 7:28pm |
11th Jan 2020 9:29pm |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
error It is not a Defender, it is a One_Ten
12th Jan 2020 3:22pm |
You could make up exactly the same thing yourself for a fraction of that price. A few lengths of cable at 1.37 a metre and a couple of relays at about 2.50 each, relay bases at 1.62 each and connectors at 1.20 for a pack of 10 Total cost about 15 quid It is not a Defender, it is a One_Ten |
12th Jan 2020 3:29pm |
