Home > Maintenance & Modifications > 2.5TD 19j oil grade. Supply and help
Alan S
United Kingdom 1987 Defender 90 2.5 TD CSW Coniston Green
Hi All
2.5 TD 19j on 1987 year.
Currently running with Semi Synthetic Castrol GTX 15w40.
Have difficulty in finding said oil make a grade now.
Q1. Is this the correct grade and type.
Q2. Can any one recommend another brand in the right grade type.
Thanks in advance
Alan S
Post #809117 6th Jan 2020 10:56pm
oneten110
http://www.millersoils.co.uk/which-oil It is not a Defender, it is a One_Ten
Post #809219 7th Jan 2020 5:36pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
buy cheap semi synthetic, 15w/40 and change every 5k miles.
Impossible to wrong as i'm sure those engine would run happily on anything.
something like this, cheap and cheerful
https://www.ebay.co.uk/itm/Synergy-Cygnus-...SwkSlbGlRv
just my opinion and is what I do. The key is changing often as higher quality and priced oil from my understanding resists oxidation and heat more and for longer whilst retaining adequate cleaning and lubrication, which is irrelevant when you change the oil much more frequently than required.
Post #809227 7th Jan 2020 6:10pm
