Home > Td5 > Defender TD5_How to shift gears
charisme1
France
Hi,
Greetings from Paris and wish you a pleasant 2020 year !
Would like to have your help please,
I'm a Land Lover Defender fan, and I bought a TD5 as a second car (year 2003 with 220 000 km).
My question concerns gear shifting with the R380 gearbox suffix "L" : If I up-shift quickly with high RPM from 1st to 2d, or 2d to 3d, I feel a crunch in my hand (not so loud to hear it in the vehicle, I can just feel it with my hand).
If I leave the RPM normal, and leave a 1/2 second pause on Neutral between these gears, all is fine.
No crunch when downshifting. The gearbox runs with new MTF94 oil.
Is this a normal behavior for a R380 ? Are we supposed to shift slowly with these gearboxes, even if I order a rebuilt one?
Many thanks for your help and feedback !
Julien
Post #808933 5th Jan 2020 10:42pm
doublecabjon
You can out-run the synchros in the r380 quite easily, which sounds like what’s happening. Is it worse when cold? Possibly a thinner gear oil can help.
A half second pause/ gear change is still pretty quick for an R380.
Post #808946 5th Jan 2020 11:17pm
landy andy
All normal for a well used gearbox. Just take your time with the changes. I find it is improved by using fully synthetic gearbox oil.
Andy.
Post #808953 6th Jan 2020 12:02am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Re: Defender TD5_How to shift gears
charisme1 wrote:
Hi,
Julien
Always, always pause for a millisecond in neutral when shifting gears especially when it is cold. That almost always solves all crunching of gears. The R380 is not a fast smashing gearbox.
If you juts bought this truck change all fluids as soon as possible. Including brake fluid , coolant, gearbox oil (MTF 94), transfer case oil , and differentials.
Good luck👍🏻 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #808955 6th Jan 2020 12:26am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Last year I have changed oil from some MTF94 compatible to original MTF94 from sealed container and there was big improvement in behavior of the gearbox. So not all MTF94 oils are the same. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #809017 6th Jan 2020 3:35pm
It's a truck, not a Mustang! Shift up slowly with a definite pause in neutral, and double declutch down changes (up changes too if you like).
My personal opinion is that the R380 is possibly the most old fashioned and generally poor gearbox of modern times. A series 1 non-synchro box is much nicer to drive.
Post #809045 6th Jan 2020 7:08pm
Fatboy Slim
Wales
I personally find they behave much better with Fuchs titan sintofluid SAE 75W-80 than MTF. Not a fan of MTF. It was great in 1996, but the world has moved on.
Post #809763 11th Jan 2020 9:51am
landy andy
Exactly what he said above 👆👆👍🏻👍🏻
Post #809764 11th Jan 2020 10:00am
charisme1
France
Hi Madtom,
When you tain about original MTF94 in sealed container, are you talking about MTF bought from dealer with green Land Lover logo ?
I put in mine the MTF94 from LR dealer. The LR part référence is STC9158. Please see picture.
Thanks for your feedback
Julien
Post #809809 11th Jan 2020 3:00pm
charisme1
France
Hi Madtom,
Julien
Post #809810 11th Jan 2020 3:00pm
charisme1
France
Hi Fatboy, Are you refering to MTF94 original LR ref STC9158 from dealer ? or another MTF ?
Many thanks
Post #809825 11th Jan 2020 4:32pm
Procta
I found this with the 300 and the same with the TD5, they do not like been rushed up the box at all. my 300 was always notchy in second and was bit of a pig, when cold. Trying to get into second gear. It was just the way the gearbox is, the TD5 is the same too, and can be notch into 3rd if am gearing quick. Due to it been remapped. Just have to pause then change gear, Sort of roll into it.
I think I read somewhere that even a Recon R380 is the same, they are just as notchy. I don't think the RT77 is a notchy unit, as my mum never mentioned anything or even notices. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #809834 11th Jan 2020 4:57pm
Fatboy Slim
Wales
Many thanks
Both. I don't use either any more, changed to Fuchs years and years ago, never looked back
Post #809843 11th Jan 2020 5:28pm
charisme1
France
Hi Procta,
Many thanks for this clear reply.
I think that mine was remapped before I bought it, because it can push it in high REVs on low gears when accelerating.
Also, on highway, I can drive it at 130 km/h, with no problem except lots of noise and vibration. So very unpleasant, that's why I don't exceed 110 km/h.
Do you know how can I be sure if it was remapped ? How can I reset it easily to return back to factory program ?
Very many thanks again,
Julien
Post #809864 11th Jan 2020 7:21pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
On most road vehicles gears 1 and 2 are designed to get the vehicle moving from a standing start, 3,4 and 5 if fitted are designed to build up road speed. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #809903 12th Jan 2020 11:30am
