Home > Puma (Tdci) > Maf sensor |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19449 |
Ford Genuine is ideal, as your Defender like mine was a Ford motor and it IS acceptable in this instance to use Ford parts.
There is no compatibility issues with the LR system in this instance. If you use the 'Search' function in the bar above, you will likely find more info on this. I have even put up the P/N you are looking for. Trying searching 'MAF and MAP Sensors' you should be able to find it. LR are charging practically double the price if not even more for these parts.. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
1st Jan 2020 4:01pm |
bunnyman Member Since: 29 May 2013 Location: herts Posts: 107 |
That’s great STEVE thank you , what do you clean them with ?
1st Jan 2020 4:16pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1726 |
I use an aerosol carb cleaner
Keith |
1st Jan 2020 5:26pm |
Cheers Kieth
1st Jan 2020 5:40pm |
I use Holts brake cleaner, both will work.
Blow though in the direction of airflow arrow on the top. And re-fit in the identical orientation of removal taking note of the airflow direction arrow. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
1st Jan 2020 6:26pm |
chrisc2306 Member Since: 02 Jan 2020 Location: Glasgow Posts: 58 |
I just ordered a new one off of eurocarparts they currently have a 50% sale with free delivery i think it cost about £45 for the new one
2nd Jan 2020 8:28pm |
