Home > Maintenance & Modifications > Range Rover Sport Seats in my DCPU
Page 2 of 4 <1234>
sako243
James - might be a possibility of sorts Whistle
The pup (well she's just turned 3), Tali, is hopefully in pup, if all goes to plan expected end of Feb. There was a possibility they might have been related to Indy (Jon and Sarah's lab) but that didn't pan out. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #807820 27th Dec 2019 10:39pm
bankz5152
Leg room pic - Front seat isnt all the way back but still comfortable for an adult.
Drawers packed! So much more tidy!
Post #807840 28th Dec 2019 10:27am
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
Nice, and interesting! Just wondering: anyone know if a DCPU is the same as a 130 HCPU, cab wise? Defender 130 HCPU Td5 MY2000
Post #808504 2nd Jan 2020 7:40pm
Roy5695
130s had a different rear bulkhead. Which meant they had a little more room at the back of the seat. There’s a couple threads on this website about putting two front seats in the back. Which gives loads of room. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #808508 2nd Jan 2020 7:59pm
RoadForce
Thanks Roy! I am aware of the other threads you're referring to, however I wasn't aware of the different bulkhead. Defender 130 HCPU Td5 MY2000
Post #808511 2nd Jan 2020 8:03pm
bankz5152
That plus no wheel arches in the cab, also helps with the space!
Thanks for the comments Very Happy
Post #808524 2nd Jan 2020 8:56pm
Chambo110
United Kingdom 1987 Defender 110 200 Tdi CSW Bonatti Grey
Seeing your pics .. I’ve bit the bullet. Just got a very nice set of black l494 .. front and rears.
Question though .. wiring them in ?? Can you elaborate at all ??
Much appreciated
Post #813330 3rd Feb 2020 8:10am
bankz5152
Havnt gone that far yet!!
Post #813336 3rd Feb 2020 8:44am
Chambo110
Your way ahead of me... so when you do get that far, would you be so kind as to update on here
Thanks
Post #813338 3rd Feb 2020 8:46am
sako243
Show me a picture of the connector - if it's like the L322 one then the motors are simply powered by the two large spade terminals. Ed
Post #813352 3rd Feb 2020 10:30am
Chambo110
Appreciate that. I’m gonna need a complete idiots guide for the wiring up part.
I will try get pic tomorrow. Unless anyone has anything .. Everything is wedged in back at the minute.
Thanks
Post #813406 3rd Feb 2020 6:02pm
bankz5152
I will post up when I do it but Its very low down on my list.
The hard part is working out which wires run the seatbelt dinger and which run the heater.
Once i find that ill be wiring the heated seats in to the LR wiring
Post #813407 3rd Feb 2020 6:20pm
Chambo110
Cool.. thanks .. not tooo low I hope
What about airbags? I see a tag on the seats saying airbag. Do I need to remove, not wire in ??
Post #813411 3rd Feb 2020 6:52pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Nice work!
sako243, can I ask where the upper setabelt mounting points are on the outer rear seats? Are they integral to the seat, or fixed to the bodywork?
Post #813413 3rd Feb 2020 6:55pm
sako243
Bodywork, they're normally part of the C pillar in the L322 but clip into the seat frame itself.
I fabricated a mounting bracket in a similar construction to the way that a 110 SW has the seat belts bolted to (basically a thick steel plate with reinforcing gussets that bolts in the front-upper corner of the rear window panel). My new one necessitated a change to a utility wagon back (which I was planning already) and there's a spreader plate that goes from the top of the tub with several bolted fixing points all the way up to the panel / roof joint and another spreader along there. More substantial and better spreading than the original LR design. This bracket also includes the sticky out bit that the seat back latches into and the seat belt bolts onto it.
The belts needed changing for longer ones too because the standard station wagon ones are too short.
Also you need to ensure that you have the brackets on the "floor" for the seats to latch into because those trigger the seat belt release and allow you to tip the seat back. If you don't have the floor "handles" then the seat won't fold backwards completely. Ed
Post #813416 3rd Feb 2020 7:17pm
Page 2 of 4 <1234>
