Home > Maintenance & Modifications > Unbolting seat sub-frame from runners
CarMan
So, new seats arrived today and I thought they would be a simply DIY swap in minutes tonight, even for a spannering imbecile but clearly not, so:
I gather from Googling that the fixings between sub-frame and runners are M8 x 35 raised head countersunk bolts but what tool do I use to get them out (preferably without damaging, as they are they are unmarked) - folk talk about impact drivers (as they will be securely lock-tighted in) which I don't have, but I'm also not sure how you would access the rear one Rolling Eyes
Advice sincerely appreciated, thanks.
Numpty! Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #805845 11th Dec 2019 8:22pm
Hey, shame nobody has given you a definitive answer, but happy to pitch in with some generic info. Never done this job in the Defender but have done it in a few different makes.
Not sure what type of bolt you are referring to, but does it have an Allen key head? You shouldn't necessarily need an impact driver, but may need an Allen key socket and something like a wobble drive extension if access is limited. If loctited in then better go for a 3/8ths or 1/2 inch drive rather than 1/4 inch to be sure and just go steady. Once a bolt is cracked it should go quite easy. Make sure you wire brush all the old dry loctite off before refitting, and be gentle and rethread by hand to start with. Not sure if all the bolts are the same length, so pay attention where you take each one out from, and make a note of any washers, shims, etc and their location.
Post #805986 12th Dec 2019 6:44pm
CarMan
Really appreciate the reply. It's actually a cross head which I believe to be Pozidrive, so have today acquired one of these from Halfords which I hope will do the job in my 3/8ths drive - thanks for the confirmation and advise regarding loc-tite. If I slide the seat forwards I now realise access should be ok Thumbs Up
Post #805989 12th Dec 2019 6:53pm
mcma1
Did you get sorted? These can’t be tricky and you can end up with the dreaded spinning rivnut . Hopefully it worked out Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #806551 17th Dec 2019 6:47am
CarMan
Yes, thanks, actually they came undone more easily than I expected Thumbs Up
Post #806558 17th Dec 2019 8:30am
