Home > Td5 > Td5 not turning off
smurf500
England 2005 Defender 90 Td5 HT Belize Green
Td5 not turning off
So have a few issues
Fuel pump stays on after ignition is turned off
Every so often ignition lights come on when ignition is turned off
Today it won’t turn off at all, just keeps running
So if I take all the wires off the ignition it still runs,until i earth the white wire
Anybody have any ideas or have come across this before?
It’s a defender 2005 td5
Post #806306 15th Dec 2019 3:35pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Ok don’t short any of those wires again while it may have worked, its a bad idea. If need be pull the fuel pump fuse to shut it off. As for the issue at hand... Perhaps your fuel pump relay is shot. Check that first.
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #806308 15th Dec 2019 3:49pm
smurf500
I already have done,is ok.
Post #806310 15th Dec 2019 3:54pm
4RF RDS
Okay have you switched the FP relay with another just to be sure?
Other things to consider:
1- Has your oil level changed at all lately? Consider it may be a leaking injector(s) seal rubber and or copper washers.
2- Consider a Faulty ignition switch or blown ignition relay
3- Consider a possible short circuit in the ECU or wiring the harness to injectors.
4- Turbo-charger bearing and seals leaking/spraying engine oil into the intake causing oil burning instead of fuel (unlikely but Might be worth looking at at some point)
others hopefully will chime in with some suggestions.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #806313 15th Dec 2019 4:50pm
smurf500
Thank you so much for the suggestions,I think no 3 is the one.but hopefully not this close to Christmas
Post #806353 15th Dec 2019 8:08pm
4RF RDS
You are welcome, Merry Christmas. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #806384 15th Dec 2019 10:22pm
roel
My thoughts.The td5 has electronic controlled injectors so if the ecu doesn't sent the injectors to open anymore the td5 should stop.
If the ecu reacts on starting but not on stopping sounds strange to me. So I would first check the power from the ignition switch to the ecu cables. Roel
2003 90 Td5 (2009-now)
Post #806424 16th Dec 2019 10:51am
dorsetsmith
pin 33 on the ecu plug is the fuel or not fuel input from the ignition switch make shore its not being back feed
with the ecu controls the main relay and fuel pump relay too
fuse 12 also feed charge ALT, speed transducer
Post #806440 16th Dec 2019 12:16pm
smurf500
Thank you all for your info,going to have a good look at it over the weekend.it stands up at work all week,my other theory furry friend might be or has given the loom a chew
Post #807072 20th Dec 2019 9:12pm
smurf500
So have hopefully found the issue,n/s or passenger wing,the plug for the alarm sounder had badly corroded so have made good and at the moment no more problems
Post #807073 20th Dec 2019 9:13pm
