![]() | Home > Td5 > Td5 not turning off |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 980 ![]() ![]() ![]() |
Ok don’t short any of those wires again while it may have worked, its a bad idea. If need be pull the fuel pump fuse to shut it off. As for the issue at hand... Perhaps your fuel pump relay is shot. Check that first.
![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
smurf500 Member Since: 08 May 2015 Location: oxfordshire Posts: 55 ![]() ![]() ![]() |
I already have done,is ok.
Okay have you switched the FP relay with another just to be sure?
Other things to consider: 1- Has your oil level changed at all lately? Consider it may be a leaking injector(s) seal rubber and or copper washers. 2- Consider a Faulty ignition switch or blown ignition relay 3- Consider a possible short circuit in the ECU or wiring the harness to injectors. 4- Turbo-charger bearing and seals leaking/spraying engine oil into the intake causing oil burning instead of fuel (unlikely but Might be worth looking at at some point) others hopefully will chime in with some suggestions. Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Thank you so much for the suggestions,I think no 3 is the one.but hopefully not this close to Christmas
You are welcome, Merry Christmas. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
My thoughts.The td5 has electronic controlled injectors so if the ecu doesn't sent the injectors to open anymore the td5 should stop.
If the ecu reacts on starting but not on stopping sounds strange to me. So I would first check the power from the ignition switch to the ecu cables. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
![]() Click image to enlarge pin 33 on the ecu plug is the fuel or not fuel input from the ignition switch make shore its not being back feed with the ecu controls the main relay and fuel pump relay too fuse 12 also feed charge ALT, speed transducer ![]() Click image to enlarge |
Thank you all for your info,going to have a good look at it over the weekend.it stands up at work all week,my other theory furry friend might be or has given the loom a chew
So have hopefully found the issue,n/s or passenger wing,the plug for the alarm sounder had badly corroded so have made good and at the moment no more problems
