![]() | Home > Td5 > Wipers suddenly stopped - not fuse? |
geostrategist Member Since: 25 Apr 2019 Location: UK Posts: 60 ![]() ![]() ![]() |
I’ve had this problem as well lately. Spindles and motor replaced, but I’m trying to find new wiper arms. All the suppliers only seem to show left hand drive vehicles for a Puma 110.
Any suggestions of which might be suitable? |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5348 ![]() ![]() |
Try these pal, if they are the same as the TD5
https://www.ebay.co.uk/itm/Land-Rover-Defe...2749.l2649 Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 128 ![]() ![]() ![]() |
Just about to try replacing park switch drive to London on sat night from oop north wipers on for the majority of the journey got to Blackwell tunnel switched them off then switched them on after exiting tunnel no wipers torrential rain dark and unable to see due to lights glaring on windscreen pulled off the a2 found fuse had blown replaced fuse ignition on then popped again hoping it’s the park switch only as intermittent not worked and wiper stopping where they want
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
I just did my park switch last night... what a crappy stupid 1950's crappy design!
had a genuine Lucas new switch, it wouldn't "clip" into place as the clip kept popping off of the switch itself. I tried poking a screwdriver (thin one), and a hacksaw blade behind it to pop it into place but it wouldn't play. So I just whipped the 2 wiper arms off, undid the large nut and pulled the whole motor out (complete with the very greasy cable, so be careful) stuck it on the workbench, took the gearbox cover plate off, and with a screwdriver you can poke it right through the gearbox and lever the C clip into place to lock the switch.... took about 5 mins all told. Just got to reassemble the dash now. |
All working fine, rebuilt the dash, changed the main washer pump (went to a scrapyard today and robbed one off of a freelander, slightly taller than the defender ones, clipped right in, better pressure, result!)
Fired it up again to "double check" it was AOK, turned wipers off and they keep going.... ![]() ![]() FFS.... lucas stuff really is sh!te.... its nearly as bad as shtpart.... |
