Home > Td5 > Wipers suddenly stopped - not fuse?
Page 1 of 3 123>
Gareth
This morning, stated the engine, turned on wipers and they moved up an inch then stopped.
Fuse is ok.
There is a faint click when the switch is moved from off to on, and a slight current draw.
Any common things to check before I rip it apart. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #805620 10th Dec 2019 1:31pm
landy andy
It could be a problem with drive system or motor. Can you feel much resistance when you try to move wipers by hand?
Can you hear the motor running?
Post #805623 10th Dec 2019 1:36pm
Gareth
Hi Andy hope your all well. The wipers both move slightly if pushed, so the rack is still connected to the gear boxes, and I can’t move them any more than the free play would allow, so I think the rack is still connected to the motor.
The motor does not run, but there is a slight current draw, and relay click when the switch is moved.
So I’m suspecting the motor has died.
Dash board out to get to it I presume? Has anyone got a wiring diagram? 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #805626 10th Dec 2019 1:45pm
4RF RDS
Pull the wiper arms off the windscreen and try again. If it works your motor is done. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #805627 10th Dec 2019 1:46pm
landy andy
How long since they last were used? (I know it’s not your everyday drive). Could the spindles be seized?
Post #805634 10th Dec 2019 2:32pm
Gareth
They were last used yesterday, daily drive at the moment for my son! I’ll try the wiper lift test when I get home. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #805636 10th Dec 2019 2:43pm
4RF RDS
Agreed, if when he pulls up the wiper arms and tries again and it does not move that would be the next thing to check Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #805637 10th Dec 2019 2:46pm
landy andy
To get access to the motor and the mechanism, it’s a very simple job, all though a many screw, operation. Easy for someone of your ability, just fiddly and not ideal in this weather if it can’t be done in your garage.
Post #805640 10th Dec 2019 2:52pm
Give both wiper arms a good jiggle back and forwards and see if that frees them. A very common problem is that as the wheelboxes and rack wear, the rack jams on the gear wheel it is supposed to be driving. A little movement of the spindle will generally free this off, but it is a warning sign that the wheelboxes and rack are on the way out.
Be careful if the ignition is on, since the wipers will probably attempt to park when freed (it is generally safer to remove the key, jiggle the arms, then turn the ignition on to see if they then park).
If this frees them, you can unfortunately expect the problem to repeat and probably become worse rather than better. A temporary fix in this case is to remove the arms from the spindles, withdraw the rack completely, turn each spindle through 180 degrees, then re-insert the rack, and refit the arms. This has the effect of bringing an unused segment of the driven gear in each wheelbox into use, and since the problem is usually a combination of wear in the rack and the gears it will often buy you some time.
Post #805645 10th Dec 2019 3:16pm
Gareth
No movement with the blades off the screen. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #805656 10th Dec 2019 5:21pm
Gareth
Spindles are definitely not seized. I’ll access the works tomorrow and see what’s going on.
Anyone got any pointers to the wiring colours and pin outs on the motor so I can test the electric side before I rip it all apart? 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #805657 10th Dec 2019 5:24pm
4RF RDS
Were it me? I’d check power to the plug at the motor next. But what has been already written is worth consideration. I doubt your wheel boxes have seized up. I’d seriously consider the motor is faulty.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #805659 10th Dec 2019 5:26pm
4RF RDS
PM me an email address and I’ll send you a wiring manual Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #805660 10th Dec 2019 5:29pm
Gareth
Sent 👍 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #805661 10th Dec 2019 5:38pm
4RF RDS
Check your email bud Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #805662 10th Dec 2019 6:09pm
Page 1 of 3 123>
