Home > Technical > Wolf Wheels and Bolts
Grenadier
Hello Def2 world.
I'm about to order a set of Wolf wheels later today as my dedicated winter set. I've heard rumours that they need a specific stud. Is this true or can I use my standard alloy bolts (of which I have two sets, one black....). Just want to make sure that when they arrive, I can actually fit them. 50cms of snow coming soon.... Whistle
Thanks in advance as always... Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #805784 11th Dec 2019 12:08pm
90 Dreamer
for the steels you need a specific nut...........
Post #805785 11th Dec 2019 12:25pm
No, you need steel wheel nuts. There are lots of posts about this subject. Despite the fact that standard studs do not protrude through the wheel nuts when using Wolf wheels, there is no need to change the studs. Vehicles were dispatched from the factory like this and they're absolutely fine. Be sure to torque them up correctly though, which for Wolf wheels is 170Nm. Darren
Post #805786 11th Dec 2019 12:26pm
90 Dreamer
Post #805787 11th Dec 2019 12:26pm
There's no need to change the studs, though I did, purely for peace of mind.
HERE'S WHY:
https://www.lincolnshirelive.co.uk/news/lo...er-1311569
https://www.mirror.co.uk/news/uk-news/girl...g-12148586 QRZ 2e0vpf
Post #805788 11th Dec 2019 12:28pm
Whilst that was a tragedy, there's no indication why the wheel came off in those story's nor any suggestion that it relates to what this topic is about. They're not even the same wheels. Darren
Post #805790 11th Dec 2019 12:46pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
As stated if torqued to 170nm they will be fine, the military swapped its old 90/110 fleet to wolf steels and added a plate in the cab stating the new torque setting, I never had any wheels come off the fleet. Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #805791 11th Dec 2019 12:54pm
Thank you for your input Anorak.
It was a tragedy.
There's no indication as to why the wheel came off.
It may not relate to what this topic is about.
They're not the same wheels.
But it is why I went for longer studs... QRZ 2e0vpf
Post #805802 11th Dec 2019 2:09pm
I wasn't, of course, questioning your choice or motive. I just wanted to be clear that there was no direct connection between them and the need for longer studs. Darren
Post #805807 11th Dec 2019 2:39pm
I followed up that case and there was no charge brought towards the driver.
Apparently there was a metallurgist who was called to inspect the Disco, but it took him 5 months to turn up!
As I initially said, there's no need for the longer studs Thumbs Up QRZ 2e0vpf
Post #805808 11th Dec 2019 2:53pm
