Home > Technical > 300tdi - Oil Leaks for a change - Pic and leak Heavy
Page 2 of 2 <12
90roy
Hi,
Would the inlet/exhaust manifold gasket cure an oil leak? I have read that an oil leak from the right side of the engine as viewed from the front may be a manifold gasket but I dont see how this can be as it doesn't seal any oil ways.
I have a leak from towards the top of the engine, which is dripping down the side so need to get it sorted. 300tdi 90 1996.
Post #805715 10th Dec 2019 10:26pm
Retroanaconda
The inlet tract is coated with oil in normal use and this is forced out of a blown gasket under the charge pressure.
Post #805726 10th Dec 2019 11:15pm
90roy
Thanks,
Is it enough to be an obvious leak, enough to drip down onto the exhaust etc...? 300tdi 90 1996.
Post #805778 11th Dec 2019 11:00am
oneten110
Very much so, the 300 tdi manifold gasket is a very well known weak point, as is the "P" gasket.
The oil leak at the back end of the engine, if not from the clutch housing, could well be the "T" seals on the rear main bearing cap. Another very well known weak point, they can be changed without removing the engine.
The intercooler should be flushed every 50,000 miles to clean out all the oil which gets in there. It is in the Land Rover service schedule. It is not a Defender, it is a One_Ten
Post #806311 15th Dec 2019 3:59pm
90roy
Thanks,
Gasket ordered and I have watched a few YouTube tutorials on how to replace it. Look reasonably straightforward.
Roy 300tdi 90 1996.
Post #806337 15th Dec 2019 7:13pm
Mo Murphy
A straightforward enough job Roy, order some new nuts too.
50 Shades of Pennine Grey
Post #806366 15th Dec 2019 9:22pm
90roy
OK, job done and leak cured. Thanks chaps.
Roy 300tdi 90 1996.
Post #808385 1st Jan 2020 5:09pm
Page 2 of 2 <12
