![]() | Home > Off Topic > Clay shooting |
Great advice sako... best reply on the forum for a long time.
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1242 ![]() ![]() ![]() |
If you have your own shotgun then there's practice you can do at home for this. Sit or stand so that you can see three corners of the room (or three distinctive points). Start with the gun on one point, swing through the second and pull the trigger but don't stop until you're aiming at the third point. Out on the grounds you can do the same thing - pick a point beyond where you would be pulling the trigger and keep the gun moving until you're aiming at it. You don't need to be exact - remember we're focusing on movement here not precision.
You sure you're talking DTL not trench? DTL has a single trap in the middle which is oscillating left and right so should be "random" as to which direction it fires. ABT is similar except the spring is wound up and the height is oscillating too as well as the swept arc being bigger. Personally I think all the "going-away" or fixed disciplines such as DTL, ABT, Trench, skeet etc., are great for practice but if you want to improve you should focus on sporting, you get more variety. Notably the DTL and ABT aren't really going to help you get out of your old rifle habits because they're all going away from you which is mostly about a steady gun. A great example of this was years ago when I started shooting for the county a few of us for a laugh decided to enter the All Round county qualifiers, 25 skeet, 25 DTL, 25 ABT and 25 sporting. Historically it was dominated by the "Skeet, ABT and DTL boys" because we "sporting boys" didn't know about it until it started being hosted by a ground we shot sporting at. However first year we went up and shot it the four of us in the car were the top four at the qualifier. The skeet boys etc., would straight the skeet and DTL and score fairly highly on the ABT but "struggle" on the sporting. Conversely we went at straighted the ABT and Sporting and dropped a couple across the DTL and Skeet. Regarding position - if you're expecting two shots to be fired (sporting stand with two clays for example) then set your stance up so that you're in the natural / relaxed position for the second shot. The first one you can always "wind" yourself up or stretch for because you've got time, but after you've fired the first shot you can then just relax and will naturally fall into position for the second shot meaning you don't have to struggle to pick up the clay. Another bad habit rifle shooting and DTL style disciplines can instill is dropping your left elbow (assuming right-handed shooter), ideally you want your elbow to be more or less horizontal - you have far more control over the gun like that. For the going away targets like DTL and so on you don't need to be as accurate sideways so that's why people tend to drop their elbow. Try both positions and you'll quickly find that you're far more in control of the barrels with the elbow up. A second habit that can be instilled is standing quite square onto the target, now I tend to shoot quite long stocked and barrelled guns for my size but I will stand almost side-on to a target and shoot directly off my left shoulder (if shooting right handed). Standing that way I can just about crank the gun around to be pointing straight in front of me (but it's awkward) but I can twist around and still shoot targets behind me quite easily. Therefore the mid-range position is directly off my left shoulder. It doesn't work for everyone but most people I've watched and coach tend to favour my approach more than don't. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2698 ![]() ![]() |
The DTL range has the sunken trap in the middle but it also has 5 other traps.
1 R-L rising 2 L-R rising 3 Stright towrds me from RHS 4 High overhead away from me V FAST, I've never hit it 5 On high bank LH side slow going to RHS I think they call it the DTL range because of the centre trap, next door range has same centre trap but the high and low house of Skeet so called the Skeet range. Once I have my guns home, I'll try your ideas 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
Sounds like a Universal Trench layout (UT). DTL is 1 trap that turns left to right within a certain arc. and the pegs are in a arc around the traphouse.
DTL squads have 5 shooters and only changed pegs after each has shot 5 targets from the peg they are on. UT is 5 sunken traps and the target can come from any of these at different heights, angles and speeds but all shooters will have had the same targets over the 25 bird shoot. Oylimpic Trap (OT) has 15 sunken traps and the 3 traps in front of you are the ones your targets come from. Both UT and OT pegs are in a straight line. and the shooter changes peg after every shot, the squads have 6 shooters with the 6th shooter standing behind peg 1 ready to move on that peg once shooter 1 has shot. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8284 ![]() ![]() ![]() |
Walfy you should be top shot on clays, you weren't with a rifle! from your own admission!
![]() James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
Top answer Sako. Seeing how easy kids find shooting is interesting, they don't think about it, they haven't been coached to within an inch of their lives, and they just enjoy it. There's a lot to be said for being relaxed and keeping it simple. |
my children pistol shoot far far better than me. their starting point wasnt great though. they have taken to practice and coaching well. (only air pistols mine) Cheers
Yep, I stood with my 12 year old on the peg on Saturday and he shot far better than me. 3 for 4 on one drive. Obviously I berated him about the fourth...🤦♂️😁
I was an Engineer, if it came to the point where I had to shoot, things had gone wrong, as a searcher I had an Infantry cordon around me while I looked for stuff that was going to go bang. After that I was either building bridges or blowing ![]() And yes, by my own admission, I couldn't hit a barn door at 5 paces ![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
