Home > V8 > Low rev misfire |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
Worst possible outcome.
Walked out to it this morning, intending to nail it once and for all. Put keys in ignition, turned it on, gave it time to pump some fuel up to the carbs, thought to give it one try just to see what happened. Of course it started and has run faultlessly in the subsequent 200 mile road test. This with original cap and rotor. Oh and the difference between black or blue distributor caps? The blue cap is a marginally tighter fit. It is not a Defender, it is a One_Ten |
7th Dec 2019 3:52pm |
Double post It is not a Defender, it is a One_Ten
montyjn Member Since: 06 Sep 2016 Location: London Posts: 41 |
Not what you need.
Any idea what the issue was then and why it didn't start first time round? |
10th Dec 2019 4:30pm |
Not a clue.
It has started and run fruitlessly ever since, which is very unhelpful. I hate it when a problem ceases without any obvious fault being found or rectified. It is not a Defender, it is a One_Ten |
10th Dec 2019 6:38pm |
