![]() | Home > Wheels & Tyres > Nordic tyres for UK winters? |
| Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 813
I have been thinking for some time about getting a second set of wolfs to fit Nokian Hakkapeliitta to as a dedicated winter combo.
Having just watched the test review below, comparing summer/all season/winter/& Nordic tyres, and am surprised how poorly the Nordic perform in any normal UK winter conditions other than actual snow & ice. Maybe I shouldn't have been surprised, after all the Nordic tyres are not designed for, or marketed here - I had just assumed that they would out-perform or at least equal normal all-season tyres in most wet & cold (i.e. 5C & below) conditions. So to me, it doesn't appear as though they are worth choosing over an all-season for the UK, when considering their improved performance in snow/ice versus the poor performance on cold wet (or even dry) tarmac. Anyway, for those who are interested: https://www.youtube.com/watch?v=bKtnczk8Mxk |
| 90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2285
yes was an interesting vid and has persuaded me to most likely put some "cross climates" on the dog shed / wifes car as it does so few miles every year albeit it is around 300ponies............
only thing that no-one seems to answer is how good the cross climates are in 'normal' (dry) summer use if you use the loud pedal a little more |
Actually, a test by the same guy came up next on my YouTube feed doing those tyres on a F150. The results were more as expected though, road bias best for roads, mud best for mud and AT a good all-round compromise! |
| miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789
Can't comment particularly on cross-climates, but winter tyres in general get squirmy and wear out fast when abused in the summer. |
Yes that's why i wanted something else that was a good year round tyre......car is lucky to do 2000miles most years so having 2x sets of wheels is a nonsense for this vehicle (and i have just a few others to look out for)
| BobT Member Since: 13 Jan 2017 Location: North Yorkshire Posts: 110
I use Mitchelin Cross Climates on my taxi, a Toyota Avensis, and think they are brilliant in all weather conditions plus I get decent mileage out of a set.
Not sure of the cost to fit a Defender but I just replaced the front two and got them for £116 each fitted on an offer from Kwik Fit. |
| Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5893
The go-to reviews of winter tyres (indeed all tyres, as far as I’m aware) is the German ADAC test or the Autobild test. As you’d expect from the Germans, very comprehensive, highly respected and have been conducted for years. Here’s last year’s for winter tyres, but they do other’s for 4x4s, summer tyres etc, just do a Google search. http://www.tyrereviews.co.uk/Article/2019-...e-Test.htm https://www.oponeo.co.uk/blog/adac-2019-2020-winter-tyre-tests With regard to using winter tyres year-round, you of course can and many people locally who have tighter budgets do. But if you can afford two sets, then I’d recommend for three main reasons: 1. Winter tyre sipes are completely different to summer (or normal) tyres which have much better patterns for water extraction and better compounds for dry grip. Winter tyres can be quite unpleasant in rain, even on damp roads where they squirm. Given the amount of rain in the UK, or damp conditions, this is worth considering. 2. On dry, warm roads they also perform less well. The compounds in winter tyres are designed to work best at 5c or less, and are a softer compound that grip better on snow once the sipes have filled with snow. As such, with excessive heat, their grip levels get worse. Indeed this is a problem in winter too, when people barrel down motorways to ski resorts and then head straight up snow-covered mountain roads. Whilst they can still work, they are not ‘optimum’. Often advised to pull to one side, grab a coffee and let the tyres return to working temps before heading up the hill. So, in summer, or in fact most of the year under ‘normal driving’, they will be less effective than standard tyres or all-year tyres. 3. Finally, for the reasons mentioned in point 2, (soft compound), winter tyres wear very quickly if driven throughout the year and will need replacing more quickly than an equivalent set of normal/summer tyres. Based on where you live, if you can afford only one tyre, you should look at how many dry days you have, damp days, wet days and sub-5c days. That’ll govern which tyre you buy, with an all-year tyre perhaps being best if you only have cash for one set. And it’s worth noting that I’ve driven a huge variety of winter tyres (Hankook, Michelin, Vredstein, Continentals, Goodyear, cheapo-things), plus Cooper and BFG year-round 4x4 tyres, and they can vary wildly in ability across all test areas: rain handling/braking, snow handling/braking, ice etc etc. Think really clearly about likely usage type/style/season/car and decide from there. No tyre does it all, good research will govern which suits your usage best, and Nokian Hakkepeliittas may not be the ones for you. I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5816
Monsieur Le Grenadier, if I remember well, you just installed a set of new Nokian winter tires. So how do you like those new LT2?
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| kallito Member Since: 21 Nov 2019 Location: Velturno Posts: 50
Hi
after I tried a steep incline over bumpy iced grass approx. 40deg incline an hour ago I thought I'll add my experience to the thread. I went down the hill and then up again reversing in low range, no slippage at all The tyres I put on my Jimy is a set of GT Radial Maxmiler WT 1000 Q in 235/85-16 As they are designed for light delivery trucks pondering around in the Alps it's not your typical choice for an offrad vehicle but works perfectly as a winter tyre and were recommended by the tyre shop owner - his brother is 4 wheeling a lot and uses those during winter, off and on road Personal experience: Having had rain, snow, slush and icey temperatures the last few weeks now the commute to work consists of dry and wet as well as iced surfaces (I live quite high up from the city, 800mt above sea level) and the roads are not cleared often as they only connect a few houses) very confidence inspiring on dry, wet, snowy and icey roads (and steep iced grass hills fair price - paid 620 Euro in a tyre shop, mounted and balanced not noisy at all and they weigh approx half of the BFG MT I had on before, Jimy bounces less around and rides much smoother now |
Salut Eric, Actually, i was so busy last season I never got round to it and just used the BFGs. However, they’re quite old now and I’m strongly considering a set of wolfs with Nokian. However, we have so few days over the season where the road is covered in snow, and so few roads with season-long hard packed snow, I’m wondering about the value in buying the Hakkeppeliittas which aren’t quite as good over tarmac, as opposed to a tarmac specific winter tyre which on review might be ‘pretty good’ on snow. If you get my drift? Dgardel, I was with Mrs Grenadier in Cervinia last weekend (bellissima) and had most of the conditions you mentioned. Mrs Grenadier refuses long drives in the DC, despite knowing how cool we’d look with the locals, so we used her TT. She has Conti WinterContact TS860 tyres and they are excellent. Slush, hard packed snow, fresh snow, tarmac with ice glaze, dry tarmac. Worked in all of them. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Apparently they do these in SUV sizes and they have very good reviews: https://alltyretests.com/goodyear-vector-4...st-review/ Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
One thing I learned. Gravity can not be taken lightly even with the Nokians installed now. My SVX weighs 2.3 tons, and a week ago I was backing down our relatively long driveway which has non slippery stone pavement, but which has a light very dry fresh snow cover. Driveway is pretty steep at 9 to 10°, and even proceeding very slow, the SVX started sliding downward. I had to release the brakes to steer it between the open gate. Was lucky to just be able to steer it onto our narrow lane and not in the opposite side neighbours garden. Even Nokians command extreme care here on our mountain.
These look like they might strike a nice balance between SUV, Winter, Snow. Good wet weather traction as well...
https://www.coopertire.fr/nouvelles/d/!/27...r-at34s-ty Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
| jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 227 |
I've got Cross Climate+ on my Subaru.. They seem very good to me - much quieter than the tyres that came off, seem to have decent grip in the wet / dry / cold / snow etc and are wearing very well. I'd buy them again... |
