Home > Maintenance & Modifications > Oil Catch Can - Provent Alternative II ~ Ryco
Page 1 of 3 123>
Just reading about another alternative to Provent from a company called Ryco.
https://www.rycofilters.com.au/Crankcase_CatchCan
Rather interestingly, they infer that Provent catch cans can be improved on by fitting one of their filters:
"The high efficiency coalescing media in the genuine Ryco replacement filters exceeded Mann+Hummel (Provent 150 & 200) crankcase filter assemblies and comfortably exceeded offerings from HPD and Process West (Terratuff). The Process West Terratuff filter has especially open filter media appearing to favour gas flow over efficiency. Imported Provent catch cans can be improved when retro fitted with a Ryco replacement filter."
Not a bad video on the topic also:
https://vimeo.com/302198656
Post #803575 26th Nov 2019 8:12am
Zed
That is interesting. I really need to fit a catch can soon. WARNING.
Post #803880 27th Nov 2019 10:22pm
hank
These look better than the Provent as the inlet and outlet can be oriented to suit installation, rather than having looping hoses, bends etc
Struggling to find a UK distributor though > 110 XS Double Cab
Post #804704 4th Dec 2019 10:57am
I've asked them that question direct ~ I'll post up any response I get back.
Response now in:
"Thanks for contacting Ryco. Unfortunately, we do not supply our products outside of Australia and New Zealand.
Have a good day."
Big Cry
Post #804741 4th Dec 2019 5:46pm
hank
Drat. I have been pondering on this... Why does the breather need to feed back to the inlet at all?
Could it just be vented to atmosphere? (hose down to ground) and the inlet feed blocked?
Perhaps not the cleanest solution in terms of fumes and occasional drips of oil, but clean in terms of inlet gas!
Cheers > 110 XS Double Cab
Post #804936 6th Dec 2019 9:13am
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I believe you need to maintain a positive crankcase pressure in the TDCI , hence it's not a good idea to vent to atmosphere. I fitted a provent a month ago and although there's not enough oil to drain yet , the filter seems to be doing its job and is wet with oil . It was fairly straght forward to fit , choosing the route and correct pipes was the hardest bit . https://www.instagram.com/hustynminepark/
Post #804943 6th Dec 2019 10:04am
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
Will it be possible to re-cause the collected oil to send it by gravity back to the engine?
For example on the same turbo discharge pipe?
Post #804946 6th Dec 2019 10:19am
Bluericky
I really don't see why you'd want to . In theory the catch-can will only be collecting small quantities of oil over a long period of time. An oil change will come around fast enough for you not to have to be concerned about losing oil.
Any oil passing through PCV would have been combusted anyway (or in reality coating your inlet manifold with crud!)
I'm sure someone will be along to explain what would be involved if you were to drain straight to the sump https://www.instagram.com/hustynminepark/
Post #804947 6th Dec 2019 10:28am
hank
I have no idea! But either way, venting to intake would not provide positive pressure. Venturi effect would likely cause negative pressure? > 110 XS Double Cab
Post #804948 6th Dec 2019 10:30am
Bluericky
I'm happy to stand corrected , I have read a couple of posts that don't recommend venting to atmosphere (saving rainforests aside) https://www.instagram.com/hustynminepark/
Post #804950 6th Dec 2019 10:41am
hank
A few views here... https://www.defender2.net/forum/topic37191-15.html
LR90XS2011: "or just vent the engine to atmosphere (via an oil catcher and filter) and plug the hole in the filter pipe, removes any chance of combustion gases oiling up your intercooler , turbo and egr, just fit the pipe back for the MOT. (all old cars / engines were vented to atmosphere and it is only emission regs that suggest you should do otherwise)"
Of course I don't know how reliable a source LR90XS2011 is, but he echo's my thoughts exactly. Unless somebody comes along to convince me otherwise I think I will try it
I noticed that my intake is so caked in crap internally, so think it would be beneficial to clean this out, and then keep it clean! > 110 XS Double Cab
Post #804952 6th Dec 2019 10:54am
Fernando
Comment this because on Ebay they offer the Pro-vent 200 with all the necessary connections for its installation, and among all that they offer, there is a non-return valve to discharge the accumulated oil to the engine
https://www.ebay.com/itm/Non-Return-Valve-...SwxixaE2vu
Post #804962 6th Dec 2019 11:58am
hank
From what I understand, the captured oil will be so dirty and out of specification that you wouldn't want it back lubricating your engine > 110 XS Double Cab
Post #804963 6th Dec 2019 12:04pm
Fernando
Thumbs Up
Post #804968 6th Dec 2019 12:39pm
rallysteve
The oil collected has come from the crank case, unless it has been through anything else, it is no dirtier than the oil in the sump! 02' 110 TD5 Double Cab Rebuild Thread
Post #804974 6th Dec 2019 1:33pm
Page 1 of 3 123>
