![]() | Home > Technical > Unexplained engine stoppage |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 813 ![]() ![]() ![]() |
That's good to hear. The engine seems to run on any old fuel but does run nicer on the posh stuff
geostrategist Member Since: 25 Apr 2019 Location: UK Posts: 60 ![]() ![]() ![]() |
Oh well, I thought I had it sorted, but it is now ‘failing to proceed’.
I lost count of the number of stoppages this morning - well over 30 in a 10 mile trip. Just recently topped up the fuel and added some Exomax. I did manage to get it to a garage, by keeping the RPM at or above 2000, and therefore having to keep in a low gear to control the speed. The fun part is trying to slow down, change gear, and keep the revs all at the same time! Possible causes may now be along the lines of VCV, fuel lines or filters. |
A cause at last. It's the fuel injector pump vapour valve, and the fuel pump pressure relief valve!
Am I allowed to say "told you so"? ![]() |
I suppose so.
