![]() | Home > Puma (Tdci) > Steering wheel wobble at 50mph |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
The steering wheel has a fair bit of wobble at 50mph. Not 45mph or 60mph. Balancing, tracking all checked and ok, the vehicle is vibrating at this speed, what should I now check/look for
![]() ![]() Tack ![]() |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
Check the suspension, damper, shock absorber and panhard rod bushes. Hub bearings and swivel preload are worth a look at too. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I had this with mine after fitting bigger tyres, checked all the stuff MG recommends with no faults found. So in desperation I changed the steering damper to a heavier duty one from OME and it fixed the wobble with only a slight vibration now at 50mph with the bigger tyres fitted. Point to note as well is that with 235/265's fitted I got no vibration/wobble at all.
you could try swopping the wheels around 2.4 90 XS
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 ![]() ![]() |
get your balancing checked again. I had to take mine back a few time to get it re-balanced even though the machine said they were balanced.
After going through a load of weights, its finally good now. I think the Balancing machine didnt like the heavy BFG ATs Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
It may be worth trying a different place to get them balanced. Years back I recall a mate saying he had to get his wheels balanced on the vehicle to solve a wobble. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 ![]() ![]() ![]() |
Same with minewhen fitted with 8x16and 265/75x16, changed them with the wifes 235's of her TD5 90 and all fixed. I have found the bigger tyre and rim combo on the 90 work fine, no wobble at all. For some reason the Puma didn't like the change. I tried steering damper change, 3 wheel balances and changed around the rim position but could not fix it. Allan |
