Home > Puma (Tdci) > Steering wheel wobble at 50mph
TACK
The steering wheel has a fair bit of wobble at 50mph. Not 45mph or 60mph. Balancing, tracking all checked and ok, the vehicle is vibrating at this speed, what should I now check/look for Question Rolling Eyes
Tack Thumbs Up
Post #80317 14th Jul 2011 10:36pm
Happyoldgit
Check the suspension, damper, shock absorber and panhard rod bushes. Hub bearings and swivel preload are worth a look at too. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #80318 14th Jul 2011 10:41pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Just pray and be happy, what wobbles is still there, but be alarmed when the big one gets silent. Never forget: cars have owner, Landrover have field service personnel.
Post #80342 15th Jul 2011 7:56am
Lorryman100
I had this with mine after fitting bigger tyres, checked all the stuff MG recommends with no faults found. So in desperation I changed the steering damper to a heavier duty one from OME and it fixed the wobble with only a slight vibration now at 50mph with the bigger tyres fitted. Point to note as well is that with 235/265's fitted I got no vibration/wobble at all.
Post #80365 15th Jul 2011 9:41am
Grockle
you could try swopping the wheels around 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #80374 15th Jul 2011 10:11am
robpenrose
get your balancing checked again. I had to take mine back a few time to get it re-balanced even though the machine said they were balanced.
After going through a load of weights, its finally good now. I think the Balancing machine didnt like the heavy BFG ATs Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #80380 15th Jul 2011 10:47am
JSG
It may be worth trying a different place to get them balanced. Years back I recall a mate saying he had to get his wheels balanced on the vehicle to solve a wobble. John
2011 Tdci 110 CSW XS
Post #80381 15th Jul 2011 10:49am
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Same with minewhen fitted with 8x16and 265/75x16, changed them with the wifes 235's of her TD5 90 and all fixed. I have found the bigger tyre and rim combo on the 90 work fine, no wobble at all. For some reason the Puma didn't like the change. I tried steering damper change, 3 wheel balances and changed around the rim position but could not fix it.
Allan
Post #80498 16th Jul 2011 1:24am
