MadTom
Machining the hole in casing, adding a sleeve a slightly machining the shaft is not so hard work. I was able to do it at home with small mill and lathe. I think, it is the only right solution. Oval hole in casing also means change in gear teath position. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
25th Nov 2019 8:49am |
hank
25th Nov 2019 9:48am |
