![]() | Home > Maintenance & Modifications > Rivnuts |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125 ![]() ![]() ![]() |
Anyone recommend a good rivnut tool .
Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 294 ![]() ![]() ![]() |
https://rover.ebay.com/rover/0/0/0?mpre=ht...2707940812
I have one of those and it’s very good... not sure I paid that much though... @steve_overland on Insta. 110 expedition vehicle with pop roof |
Horneteer Member Since: 10 Feb 2015 Location: Cornwall Posts: 60 ![]() ![]() ![]() |
I have the Sealey version of this. Very good and well worth it. ![]() |
Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 202 ![]() ![]() ![]() |
get one with long handles as some of the nuts are hard to compress
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1068 ![]() ![]() ![]() |
I have a cheap and nasty one. I'd strongly recommend following the advice of those above.
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3862 ![]() ![]() |
I needed one to fit new mudguard brackets,
https://smile.amazon.co.uk/FreeTec-Threade...mp;sr=8-10 Cheap and cheerful plus under the car without being jacked up it worked fine? Wear some gloves and I used an old tea towel round the handle to squeeze as much as I can... A year later the Mudguard brackets are still on ![]() ![]() |
many thanks lads , I didn't realise they cost that much
MaxRPM Member Since: 15 Jan 2013 Location: South Staffs Posts: 1114 ![]() ![]() |
In my experience never buy aluminium rivnuts, they strip too easily, corrode and and can come loose. Phil
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
"In my experience never buy aluminium rivnuts, they strip too easily, corrode and and can come loose. Phil"
Totally agree, alloy rivnuts should only be used for fitting small lightweight items and/or to alloy panels where you don't want a mismatch of materials. I always use steel rivnuts (hence my recommendation of the tool above) and assumed others thought the same. ONE LIFE, GET IT! |
https://www.ebay.co.uk/itm/MXITA-Electrica...%7Ciid%3A1
anyone got this one ? |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
![]() Click image to enlarge I have one similar bought in Aliexpress around 1 year ago. Quite good results but be carefully with the tool force to do not damage the rivnut. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
