![]() | Home > Technical > 4 pin diff question |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
Can I fit a 4 pin diff to the front of a 2008 Defender as a direct replacement?
I'm told not if you have ABS but I don't understand why. Peter |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
Yes as long as it is the correct diff.
| oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741
I cannot see why the fitting of a 4 pin diff would make any difference to an ABS equipped vehicle.
The function of a differential is not affected in any way whether it is 4 pin or 2 pin It is not a Defender, it is a One_Ten |
| BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403
After the 2 pin diff's long history of strong and dependable service with the lesser engines No problem with fitting any sort of diff with ABS in my view. Any open diff has the same function, a torque biasing system will almost certainly help the ABS, and a fully locking diff will just mean the ABS doesn't function when the driveline is all locked up. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18046
True, but don't forget that the TDCi is the torquiest engine ever fitted to a mass production Defender, and also produces a lot of torsional vibration, both of which really hammer the transmission. |
It's interesting (if a little OT) to note that they upgraded the front diff to a four-pin, and then downgraded the centre diff to one made of cheese to compensate
| All times are GMT |
