Home > Puma (Tdci) > New battery time, but how big?
Jimbob
Wales 2015 Defender 90 Puma 2.2 HT Corris Grey
Hi all,
My 2015 2.2 battery is on its way out, I have aftermarket security which means it goes flat after a short while and after this happening a few times over the years combined with my short journeys it’s now struggling, barely even lasting a week. I’m after recommendations for a bigger battery that can hold up to infrequent use, and hold a charge longer with accessories attached such as my security. I appreciate I need to get a charger too and that’s on the list, but I don’t want to have the truck plugged in all day every day either, so looking for maybe a deep cycle/leisure type battery that can take a bit of abuse?
Any advice greatly appreciated!
Thumbs Up 2009 Defender County Hard Top (gone 😞)
1990 200tdi defender off roader
2015 Defender XS Hard Top (awaiting delivery 😄)
Post #799267 24th Oct 2019 8:57am
Mdm
we use this at work
you can then take the info and cross reference it to other makes and brands
we have just swapped a 3yr old one that failed under warranty no issue
https://batterylookupgb.yuasa.co.uk/
Post #799270 24th Oct 2019 9:20am
Jimbob
Ok thanks mate, just put the info in and the upgrade they recommend is available from GSF for 113 quid which is a bit of a bargain! Hope it does the job now lol 2009 Defender County Hard Top (gone 😞)
Post #799374 24th Oct 2019 8:47pm
Mdm
yep its a pretty good tool i know a few other battery firms have them but this one is fairly quick and easy to use
Post #799375 24th Oct 2019 8:51pm
jst
see other thread in this, lots of info in there. https://www.defender2.net/forum/topic69760.html Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #799387 24th Oct 2019 9:42pm
BobT
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
I think the same one is on Amazon for £105.99 with free delivery if you’re a Prime Member.
https://www.amazon.co.uk/Yuasa-YBX5019-Sil...l_huc_item
Post #799427 25th Oct 2019 7:16am
spudfan
Ireland
Yep 019 is the way to go.
Our 2008 Puma 2.4 is still on it's original battery. At the onset of each winter I keep saying that I must change it, but I never do. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #803130 21st Nov 2019 10:51pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
so do I.
I'm just wondering, if it might go flat suddenly ...
Post #803136 21st Nov 2019 11:56pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
It won't go 'flat suddenly' but what will happen is that one day as the battery capacity and performance declines, the lines will cross on the graph that shows the battery's ability to deliver cold cranking amps versus the engine's need for them, usually on a cold morning when the battery is less capable and the engine is most demanding, and then it won't start, which is much the same level of irritation as being completely flat!
I used to run a business that sold batteries in a previous life, and you could wake up on the first properly cold morning of winter and know that you'd sell a week's worth of batteries in one day. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #803142 22nd Nov 2019 9:42am
Bluest
If you really want a lot more capacity, with not much effort, you can fit two standard size batteries alongside each other in the seat box and connect them in parallel. You would need to rehome the jack and wheel chock. 2007 110 TDCi Station Wagon XS
Post #803144 22nd Nov 2019 10:04am
I see the Exide ones seem to have 50 extra CCA over factory. Mines also the factory fit battery, staggering how well and how long they have lasted so well!
Only thing that concerns me a bit is that the battery posts have the same footprint and will lock in the tray too.
Otherwise, the post clamps won’t fit, or the clamps on the tray. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #803157 22nd Nov 2019 11:49am
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
(I'm still on the original - now over 12yrs old, 70K miles!)
Post #803166 22nd Nov 2019 1:51pm
Basically the same as mine. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #803177 22nd Nov 2019 3:25pm
G4UJS
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
I bought ne of these, Exide EA1000, less than £90 including VAT and delivery from Tayna
The CCA is 900
Seems fine
Regards
Rob
Post #803179 22nd Nov 2019 3:30pm
htb2
Wales
this wee
05 TD5 on 212K miles and just starting to die, alternator died this week and it did not last long on just the battery.
Post #803219 22nd Nov 2019 7:13pm
