![]() | Home > Puma (Tdci) > New battery time, but how big? |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1652 ![]() ![]() |
we use this at work
you can then take the info and cross reference it to other makes and brands we have just swapped a 3yr old one that failed under warranty no issue https://batterylookupgb.yuasa.co.uk/ |
Jimbob Member Since: 17 Mar 2011 Location: Gower Posts: 68 ![]() ![]() ![]() |
Ok thanks mate, just put the info in and the upgrade they recommend is available from GSF for 113 quid which is a bit of a bargain! Hope it does the job now lol 2009 Defender County Hard Top (gone 😞)
1990 200tdi defender off roader 2015 Defender XS Hard Top (awaiting delivery 😄) |
yep its a pretty good tool i know a few other battery firms have them but this one is fairly quick and easy to use
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8336 ![]() ![]() ![]() |
see other thread in this, lots of info in there. https://www.defender2.net/forum/topic69760.html Cheers
BobT Member Since: 13 Jan 2017 Location: North Yorkshire Posts: 110 ![]() ![]() ![]() |
I think the same one is on Amazon for £105.99 with free delivery if you’re a Prime Member.
https://www.amazon.co.uk/Yuasa-YBX5019-Sil...l_huc_item |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
Yep 019 is the way to go.
Our 2008 Puma 2.4 is still on it's original battery. At the onset of each winter I keep saying that I must change it, but I never do. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 588 ![]() ![]() ![]() |
so do I.
I'm just wondering, if it might go flat suddenly ... |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
It won't go 'flat suddenly' but what will happen is that one day as the battery capacity and performance declines, the lines will cross on the graph that shows the battery's ability to deliver cold cranking amps versus the engine's need for them, usually on a cold morning when the battery is less capable and the engine is most demanding, and then it won't start, which is much the same level of irritation as being completely flat!
I used to run a business that sold batteries in a previous life, and you could wake up on the first properly cold morning of winter and know that you'd sell a week's worth of batteries in one day. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4289 ![]() ![]() ![]() |
If you really want a lot more capacity, with not much effort, you can fit two standard size batteries alongside each other in the seat box and connect them in parallel. You would need to rehome the jack and wheel chock. 2007 110 TDCi Station Wagon XS
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20915 ![]() ![]() |
I see the Exide ones seem to have 50 extra CCA over factory. Mines also the factory fit battery, staggering how well and how long they have lasted so well!
Only thing that concerns me a bit is that the battery posts have the same footprint and will lock in the tray too. Otherwise, the post clamps won’t fit, or the clamps on the tray. ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___[/size] ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 813 ![]() ![]() ![]() |
(I'm still on the original - now over 12yrs old, 70K miles!)
Basically the same as mine.
![]() ____\We|Will|Win/___[/size] ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
G4UJS Member Since: 20 Jan 2019 Location: Shropshire Posts: 226 ![]() ![]() ![]() |
I bought ne of these, Exide EA1000, less than £90 including VAT and delivery from Tayna
The CCA is 900 Seems fine Regards Rob |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 547 ![]() ![]() |
05 TD5 on 212K miles and just starting to die, alternator died this week and it did not last long on just the battery. |
