Home > Td5 > Td5 starting
Page 1 of 3 123>
Gozy
United Kingdom 2004 Defender 90 Td5 SW Aintree Green
Td5 starting
Hi all. Developed a potential problem. We have a defender TD5 2004 Reg. She normally starts on the button no problem. It’s happened 3 times now turned over 2or3 times so stopped. Started again starts as normal. This has happened after it’s stood all day or night. I have changed the injector seals and copper washers about 5000 miles ago because of noisy fuel pump and very poor starting. This did the job fine, which was done with OEM seals and copper washers by myself which I took great care with. Because of the time of year and weather haven’t had the chance to check other things. What should I look at first assuming the job on injectors is okay Seems to be fine when started. Thanks in advance Gozy.
Post #803123 21st Nov 2019 9:48pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Some things to consider which seem to be fairly common.
1- Fuel filter?
2- In line fuel valve in the filter head?
3- Fuel Pump?
4- Oil in the ECU loom (red plug)?
Good luck Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #803124 21st Nov 2019 10:01pm
Gozy
Td5 starting
Brilliant thanks for your help and reply 4RF RDS. Will get at it but still open to suggestions. Gozy.
Post #803132 21st Nov 2019 11:14pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Mine did the same and needed a new fuel pump - it wasn't delivering enough pressure to satisfy the ECU. The plastic fuel lines were renewed at the same time because they'd become brittle.
Post #803156 22nd Nov 2019 11:25am
rallysteve
What is the actual symptom, can't quite be sure from your initial description?
Does it just churn away when you turn the key but not start?
Does it start but then splutter and die?
Does it just stop turning over when the key is turned?
Post #803158 22nd Nov 2019 11:50am
Gozy
Hi rallysteve.
Problem is turns over 4or5 times will not start. Turn key back and turn key again will start ,but it did take two times of this ,this morning. When it starts it seems to run fine. Just thinking maybe glow plugs 🤔 thanks Gozy. Pa it done 107000 miles and probably not changed.
Post #803160 22nd Nov 2019 12:09pm
dorsetsmith
test them before remove them save your time
To test glow plugs, start by getting a multimeter and setting it to ohms. ... Next, remove the caps or connectors to the glow plugs and connect the negative multimeter lead to a ground point in the engine. Once the negative lead is secure, attach the positive lead to the top of the glow plug.
good glow plug reading is ohms 0.7 prox
only 4 glow plugs fitted
Post #803174 22nd Nov 2019 3:17pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
If it needs glow plugs it’s past it I would say.
I don’t think they actually need them, mine doesn’t and from what the OP says there’s doesn’t normally.
I think they were fitted to satisfy emissions , but are not really needed to start.
So I would be looking elsewhere. I would suspect fuel, but equally a lot of people say to check the crank sensor, which might make sense.
A Nanocom would possibly steer you in the right direction?
Post #803213 22nd Nov 2019 6:43pm
lightning
I just had the same fault on my friends 2005 Defender TD5
Changed injector seals, wasn’t that. Changed diesel filter housing, no difference
Changed the battery....starts instantly
Battery still seemed to turn the engine over OK but was the original one from 2005.
Post #803221 22nd Nov 2019 7:27pm
Piggle
2003 Defender 90 2.5 TD XS CSW Bonatti Grey
Recently had very similar issue with mine. Would take 2 or 3 attempts to start when cold. Just got back from independent Land Rover garage week. They changed all 4 glow plugs and now starts on the button. Seemingly 2 were completely dead and the other 2 were on last legs.
Post #803848 27th Nov 2019 7:31pm
Gozy
Starting problem
Hi thanks very much for your help regarding our starting problem. First port of call was to change the fuel filter which I’ve done and it’s sorted. I am a little surprised the exciting One had done only 5000 miles but I suppose if it’s dirty it’s done it’s job. I’ve been buying Esso fuel for the last 12000 miles and she seems to of been fine. Don’t run the tank to empty or near so a mystery. Still I now have some spares in a new return valve and little reddish rubber valve which wasn’t mentioned in the work shop manual will take photos and post , oh and four new heater plugs. Thanks again to all happy Landying.
Post #804261 1st Dec 2019 5:33am
dorsetsmith
fuel bug scat bloke fuel filters and pump
Diesel bug is contamination of diesel fuel by microbes such as bacteria and fungi. ... The presence of water then encourages microbial growth which either occurs at the interface between the oil and water or on the tank walls, depending on whether the microbes need oxygen.
treat with Diesel & Biodiesel Biocide
Post #804274 1st Dec 2019 9:58am
Re: Starting problem
Why do you think running the tank close to empty would make a difference? The fuel pick-up is still in the same place!
Post #804300 1st Dec 2019 2:35pm
othorton
United Kingdom 2005 Defender 90 Td5 CSW Java Black
Strangely mine has started doing this as we've moved into winter. Irrespective of how long I leave the ignition on before turning the key, it turns over once and then conks out, then on the second attempt it starts right up. This only happens if the defender has been sat overnight and gotten very cold. If I'm using it during the day it's absolutely fine. Has just had the fuel pump checked so it's not that.
I don't really have an issue with turning it over twice first thing in the morning, providing doing that isn't damaging the engine in any way.
Post #804428 2nd Dec 2019 12:45pm
excossack
Mine starts much better since having the injector seals done and timing was also slightly out on mine. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #804429 2nd Dec 2019 12:48pm
Page 1 of 3 123>
