Home > Maintenance & Modifications > Help needed from those with Fox 2.0
Page 2 of 2 <12
jst
You have checked full bump, no springs in it take it? Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #802911 20th Nov 2019 8:51am
JOE_130
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Java Black
We've got fox 2.0's on two of our vehicles and on both occasions I've had to use the original Landrover bushes with the original landrover washers turned upside down (not sure what the big spacers/washers should be called that support the bush?).
If you fit the Fox washers they hit the supporting metal cup the bush sits in on the rear axle. If you look at the vehicles they run these on in the states they all have completely flat shock mount brackets without any "cup" for the bush to sit in so the Fox parts work well.
We had one of the old 2.0's break the threaded bar out of the shock housing once where I'd fitted the fox washers and it had gradually cracked and damaged the shock where it impacted and levered against the cup on the axle as it articulated.
When I've used the OEM bushes and washers I've always found the fox's to be an awesome shock and never had any problems. Going to swap out my rears on the 130 to include the high and low speed adjustable compression damping to cope with the vast difference between laden and unladen - definitely under damped with a ton in the back.
Post #802943 20th Nov 2019 2:29pm
mynamesbuck
United Kingdom 2014 Defender 110 Puma 2.2 USW Loire Blue
Thank you very much Joe, this is certainly something I will take a look at this coming week!
Post #803260 22nd Nov 2019 11:44pm
Co1
jst wrote:
Std springs, std bump stops and std length shocks? Or longer shocks?
All standard JST.
Joe: that’s exactly what I have ended up doing.
Post #803269 23rd Nov 2019 8:42am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Co1 where did you get the standard bottom bushes from? 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #803853 27th Nov 2019 8:27pm
Co1
Local Indy. Paddock do them though.
Post #803864 27th Nov 2019 9:31pm
pj2106
Got varying views on the bushes some say they fit fine then your experience??? 2008 110 2.4 XS Utility (Hagrid)
Post #803872 27th Nov 2019 9:56pm
Co1
There was no issue with fit, they were just stiff as hell!
Post #803875 27th Nov 2019 10:01pm
pj2106
Did you use original washers or the fox ones? 2008 110 2.4 XS Utility (Hagrid)
Post #803876 27th Nov 2019 10:02pm
Co1
Fox ones, but inverted so that the rim of the washer as it were is facing away from the cups.
Post #803884 27th Nov 2019 10:37pm
Page 2 of 2 <12
