![]() | Home > Puma (Tdci) > puma [tdci] coolant |
DOUG MALGARIN Member Since: 27 Jun 2017 Location: WEYMOUTH Posts: 12 ![]() ![]() ![]() |
HI what anti freeze I should use in my 2.4 tdc and best way to drain it .
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
I've just done mine used Comma Long life OAT, i pulled the pipes of the fuel cooler and it drained down just fine DEFENDER 90 TDCI XS,
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
*Post corrected above.* ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ Last edited by custom90 on 3rd Dec 2019 8:06pm. Edited 1 time in total |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
I use this from COMMA.
Xstream® G30® Antifreeze & Coolant Concentrate https://www.commaoil.com/passenger-vehicles/products/view/351 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
That's the one I used got it off amazon DEFENDER 90 TDCI XS,
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 210 ![]() ![]() ![]() |
Can anyone tell me what the longevity of the engine coolant is, ie Texaco XLC?
Steve, the motul one from Opie oils you have found looks ideal looking at the specs. Is changing it all out a difficult job, there appears to be pipework everywhere ![]() Glen |
Drain from the thermostat drain hose, not too bad a job.
You do need the workshop manual for the bleeding process however or the info may be on here already. It isn't very complicated, just takes a bit of time, I changed my own water pump and I'm not an expert mechanic / engineer so you should be fine. The Motul does meet all specs, in mine I used pre mix and I noticed the running temp was down just a couple of degrees which is good. On my gauge before it was half way, after a touch below half way in normal conditions. I'm not keen on the concentrate method as it can introduce a lot of impurities into the system using tap water as it isn't de-ionised and giu can get calcium build up etc etc. Lifespan is about 5 years so, to me cost on that isn't a huge issue. Please be responsible with disposal, don't let animals get near it. (Poisonous.) and keep off of paintwork. But you no doubt already know this. ![]() Puma quantity of fluid required is just over 10 litres I think approximately so you need 11L. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I simply drained mine from the fuel cooler hoses, squeeze and pull off, remove the coolant header tank cap and the screw in the heater hose.
All quite easy and can be done with no tools except a large flat blade screw driver for the top hose screw plug, took me 1 hour max. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
I've just topped mine up with the recommended LR OEM Coolant (2.4tdci puma)
LSTC50529 / £13-73(inc) for 1Lt… maybe on a full drain and replace i'll be looking to alternatives... ![]() ![]() https://www.defender2.net/forum/topic83242.html |
Thank you for the info chaps. Two questions though; where is the thermostat and the screw in the heater hose located?
Best to ask to save me rooting around resulting in much head scratching. Oh, when draining off would a builders bucket (clean of course) be suffice to catch the old coolant as I wouldn’t want to spill any prior to disposal. |
