Home > Technical > Heater inlet plug/drain - how useful?
Page 2 of 2 <12
90 Dreamer
cheers for the info
where are the others on the Puma specifically please??
Post #802712 18th Nov 2019 5:11pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
As with all these things, they are there for a reason, I have thought about cutting it out previously after suffering the sauna syndrome when it was blocked, but it's easy enough to keep it clear and leave it in place Thumbs Up sorry if that doesn't help the above post, I didn't realise tdci Defenders had more!
Post #802713 18th Nov 2019 5:15pm
dorsetsmith
90 Dreamer wrote:
cheers for the info
only trouble is JLR only sale you hole thing Puma specifically
Post #802715 18th Nov 2019 5:25pm
This is the primary reason that I've fitted a 'snow guard' - it keeps the rain and crud out of the heater duct in the first place. Darren
Post #802747 18th Nov 2019 9:12pm
This is the approximate locations of the 3x drains.
One is closer to the inlet the other two are in line with each other just before the outlet all in the same section of plastic ducting.
Last time I looked I could only seem to find aftermarket ones, but they are just as good on such an item.
The areas marked in red is their location approx.
As expected the rear two are a pain to get at.
 ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #802800 19th Nov 2019 1:16pm
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
You can use the drain valves from the 200TDI (product number MUC2417), they do fit the the Puma air duct holes to replace the original ones. Works a treat, and cheap.
/Mat
Post #855767 13th Sep 2020 6:52am
Page 2 of 2 <12
