Home > Wheels & Tyres > Modifications to fit wolf wheels
rleslie
Scotland 2007 Defender 110 Puma 2.4 XS CSW Epsom Green
Hello,
I'm not mechanically minded, hence the stupid question....... I'm thinking of changing my alloy wheels and going for a set of wolf wheels. What modifications if any do I need at the hub to fit wolf wheels with nuts? Whats the rough cost? Is it an easy job?
Post #802685 18th Nov 2019 11:44am
No modifications of any kind are required.
There is an internet myth that you need to fit longer studs, but you do not. All you will need is to ensure that you get a set of the correct wheel nuts for steel wheels, as they are different to those for alloys.
it is an easy job - jack up, remove alloy wheel, fit steel wheel, lower jack!
No costs involved other than the new wheels, tyres and nuts.
Post #802687 18th Nov 2019 12:00pm
And if you're buying new wheel nuts, I can highly recommend Wrington Engineering blackened, closed end ones:
 Darren
Post #802691 18th Nov 2019 1:07pm
90 Dreamer
whats the spec of the 2x wheel nuts?? i believe they are M16x1.5mm thread pitch
do they need a flat nut or tapered for the steel wheels??
Post #802694 18th Nov 2019 1:56pm
From Series III onwards, they're M16x1.5mm and they're tapered. Darren
Post #802696 18th Nov 2019 2:11pm
rleslie
Hi LandRoverAnorak, those wheels look amazing.
I just phoned my local LR dealer and they are quoting £140.40 inc vat per wheel. Ouch.
What size of tyres have you got on them? Is that 235/85/R16?
cheers
Post #802703 18th Nov 2019 3:17pm
JOW240725
I fitted extended wheel studs, as the original only studs only extended half way thru' the wheel nuts, which I personally wasn't happy with. The studs are now too long.
 James
Instagram @suffolk_rovers
Post #802705 18th Nov 2019 3:41pm
Thanks Smile Yes, they're 235/85 General Grabber AT3's. Darren
Post #802746 18th Nov 2019 10:07pm
hank
Damn you. Piqued my interested big time and they're out of stock Laughing > 110 XS Double Cab
Post #802766 19th Nov 2019 6:18am
Sorry Laughing Darren
Post #802775 19th Nov 2019 9:32am
rleslie
Hey Darren, I see from a previous post your wolfs are from Terrafirma..... You happy with them? Quality ok? Seems a fraction of the price of LR ones. I'm guessing at 1500kg they will be up to off-roading???
cheers
Post #802782 19th Nov 2019 12:30pm
They are absolutely fine and the 1500kgs load rating is still stronger than virtually every other LR wheel. Darren
Post #802791 19th Nov 2019 1:34pm
hxk494
Hank, If you're still looking for closed end black nuts I've got a set of 23 I bought earlier in the year. They've done around 4000 miles to spain and back but have gone back to alloys so now surplus to requirements. Looking for £50 for them, were £69 new. 1996 300Tdi Defender 110
Post #804163 30th Nov 2019 1:43pm
cheers
Shop around on OEM rims, there's a good reason they are rated at 2,200kg ; ask yourself the question why a pattern wheel maker down rates their's to only 68% of OEM...
Post #804218 30th Nov 2019 6:46pm
Grouse
For the small additional cost of genuine which can be bought quite reasonably if you look around, I wouldn’t entertain fake wolfs - or any fake / copy wheels - the small extra cost for piece of mind is worth the tiny extra cost - plus fake wheels in an accident could be an issue with insurance unless you notify them and get cover agreed - it’s simply not worth the risk finding you are not covered and end up with a liability bill for the rest of your life or losing your home over. 2017 Range Rover L405 Vogue SE V8 Diesel #16
Land Rover 110 300 TDI
Post #804223 30th Nov 2019 7:20pm
