![]() | Home > In Car Electronics > What sized battery |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406 ![]() ![]() ![]() |
For single battery I would use https://www.tayna.co.uk/leisure-batteries/numax/cxv30hmf/ good mcca, excellent durability and good value. I run these for single battery options or 2 x 27s for twin battery setups in several less, tri, Tgvs, td5 and puma for last 12 years or so. Cheers
https://www.tayna.co.uk/car-batteries/enduroline/19001340/
as close to delphi GP31 spec battery fitted by LR or Manufacturer: Yuasa Type : 640SHD Voltage = 12 Volts Battery Capacity: 115Ah Cold Cranking Amps (CCA), EN(1) = 1000 Dimensions: Length = 329mm, Width = 171mm, Height = 240mm Terminal Type T1 - Weight = 26.2 Kg Manufacturer Warranty 2 Years |
