![]() | Home > Maintenance & Modifications > High beam wiring question. LED light bar |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
Do you want it to come on with the main beam all the time or manually on when selected?
Or Switchable between on with main beam, off or on manually? The first one you can just tee a relay activated by main beam to the positive wire for the light bar. The second one you need a 3 way switch with one pole to permanent live, one to a relay activated by main beam and the common to the positive of the light bar So option 1 will be as you are currently but the light bar will alway come on with main beam or be switched on manually. (no isolation) Option 2 gives you ON, OFF or on with main beam 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
| 2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562
Option one is the way to go it would seem.
So, just tap into the Live feed on the switch side, add a relay back in to the high beam feed then. The other way would be a pain for me now, as the switch is now up on the roof console, all wired up and the headliner back on, not taking all that down again. Thanks. |
Yes option one will be fine.
The switch physically isolates the main beam from the switch feed and the relay will physically isolate the main beam from the switched live. If you were to flash the lights with the light bar manually on it would make no difference 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Awesome, thanks
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18037
In case it is of interest, my light bar is wired using a modified Defender light switch (the off-side-head stalk switch) mounted in the unused stalk position on the right of the column. The modified switch controls the light bar, centre position is off, towards driver connects to main beam, away from driver is permanently on.
The switch mod is straightforward and used a failed switch from the scrap bin. |
| bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239
Afaik it isnt legal to use any auxillary lighting on the road unless the lighting sits inline (within reason) to the factory fitted headlights.
I may be wrong but i do remember reading something along those lines. |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
You're wrong, I'm afraid. As long as they point forward and are centred around the centreline of the vehicle then they're fine. There are detail rules around vertical positioning but they're for much bigger or oddly shaped vehicles and not relevant to a Defender.
What they must be to be legal is wired to go on and off with the main beam. Independently switched aux. lights are not allowed. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
