Home > Tdi > Steering help |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1114 |
Got a load noise for the power steering pump steering went stiff the belt has slight wear on the one side .
How much resistance should there be when you turn the pump wheel? . I've turned the steering from side to side now the noise has stopped and steering is back to normal. |
28th Oct 2019 4:16pm |
Anyone tell me if the pulley on the power steering pump should spin freely or have resistance
1st Nov 2019 2:42pm |
At slow speed your power steering pump will spin freely only way to test the out put presser with gauge kit
see link to work shop Manual show power steering pump testing https://1drv.ms/b/s!AtZSoWFHDgnGhUfhpexEdGpupY2Q?e=hg4MCm |
1st Nov 2019 4:37pm |
Click image to enlarge Found it. The belt was just on the edge, looks like the shaft has come loose. |
9th Nov 2019 11:47am |
not good news but at lest you nailed down |
9th Nov 2019 3:05pm |
find this
key has failed Last edited by dorsetsmith on 10th Nov 2019 2:54pm. Edited 3 times in total |
9th Nov 2019 8:32pm |
new one fitted
10th Nov 2019 8:35am |
One I did do to the last one , was the penny trick behind the pulley tensioner to stop the belt squeaking , whether this didn't help I'm not sure.
10th Nov 2019 11:20am |
