![]() | Home > Puma (Tdci) > 2.4 Puma noise on startup (sound + video) |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1121 ![]() ![]() ![]() |
congrats! Hard to make out. Do you mean the short noise when you tilt the phone?
(also takes a bit too long to start IMHO) |
MiserereDeus Member Since: 09 Nov 2019 Location: Northern Ireland Posts: 3 ![]() |
Thank you
![]() Yeah it does seem too long, it is cold here at the minute but still |
hopeydaze Member Since: 11 May 2011 Location: Bath Posts: 30 ![]() ![]() ![]() |
I get the same noise, so while I can’t offer a solution at least you have company. Mine’s a 2010 and I’ve owned it for just over a week. Loving it despite the noise after start up
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3672 ![]() ![]() ![]() |
do the clutch rattle test, could just be the clutch springs settling down.
start the car in neutral without the clutch depressed, press the clutch if there is a rattle that disappears when the clutch pedal is depressed the clutch springs are probably loose, this is most noticeable in a garage or next to a wall. clutches can rattle for ages without causing any issues, however some get that bad the springs come out and damage other bits DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
Tardis Member Since: 24 Nov 2017 Location: Hannover Posts: 22 ![]() ![]() ![]() |
I can't hear anything unusual, I think you're a bit oversensitive. There are lots of brackets, shields and the like attached to the engine and gear boxes which may give a rattle here and there.
But I agree with the above posters: your starter needs a bit long to kick the engine, my 2010 Puma starts after half your revolutions even at 3°C. When was the last time your filters (fuel&air) have been changed? |
Thanks for all the replies everyone, it turns out when the noise occurs on start my brake pedal vibrates with it so probably ABS.
As for the long start, yeah I’m going to swap out the filters as im not sure when they were last changed. Also will check the battery level |
That really sounds like you need a new battery or starter! It's turning over slowly, should be starting after fewer turns and shouldn't be obviously slowing down after such a short time cranking.
