Home > Technical > 200tdi front stub axles
mark23
United Kingdom 1989 Defender 90 300 Tdi HT Corris Grey
Hi
Im new to this forum and need help with a problem I have with new stub axles.
Ive fitted the bronze thrust washer to the stub axle after checking it will fit the cv axle.
After pressing this into the axle it now wont fit to the cv axle.
Am I missing something?
Thanks
Post #800181 31st Oct 2019 12:18pm
jst
Pressing the bronze Bush onto the stub you mean and now on assembly the cv doesn't stick out of the stub far enough?
If so take stub off, reseat shaft/cv and go again Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #800203 31st Oct 2019 4:21pm
mark23
Hi
Thanks for the info I guess its a really tight fit.
Post #800932 5th Nov 2019 8:29pm
Retroanaconda
I’ve had this with poor quality aftermarket bronze bushes, the CV doesn’t fit into them properly once they’re fitted into the stub axle.
Post #800945 5th Nov 2019 9:13pm
mark23
Hi
Thanks for the info now all sorted.
Post #801610 10th Nov 2019 12:00pm
Normal engineering practice with bushes of this type is to reamer them to size after fitting, but this shouldn't be necessary in this application.
Post #801614 10th Nov 2019 1:32pm
mark23
Hi
What I found strange was when removing the old bush from the old stub axle it then didn't fit the cv shaft it was originally fitted to.
Post #801616 10th Nov 2019 1:39pm
