Home > Td5 > TD5 Cut-Out
Page 2 of 3 <123>
Mdm
this ran ok but did show faults when read on a hawkeye.
be careful on CPS sensors lots of new ones don't work correctly fresh from the box, buy a better quality one if poss and if it doesnt cure it then keep it as a spare .
i wouldnt drive it far but these things take time to find and more time to cure.
Post #794762 23rd Sep 2019 8:57pm
lightning
Fit a new injector harness anyway, it’s cheap and easy to change.
Post #794807 24th Sep 2019 8:37am
othorton
United Kingdom 2005 Defender 90 Td5 CSW Java Black
Hi All,
I thought I'd give you all an update as the defender has just been returned to me. Before I do, I just want to say here (and I will post in the general section also) how fantastic the service provided by Jones Bros 4x4 up in Ryll was. Whilst the Defender was just inside warranty, Jones Bros have been extremely accommodative. Not only have they gone above and beyond to provide a great service, but they have also paid for my warranty work to be completed at my parents' local indy Rockingham Landrovers in Leicestershire to save me having to drive all the way from London to Wales.
After a horrendous journey up from London to Leicestershire (9 hours, an absolute richard of an AA callout refusing to call a tow truck culminating with 2 hours on the side of the a14 at 2 in the morning) I finally managed to limp the defender to rockingham.
- they could not recreate the issue despite driving it for approx 75m
- there were no faults recorded re. crank position sensor and wiring appeared fine
- as per instruction from Merv at Jones they installed a new injector harness (the previous harness showed no real signs of wear and tear)
- there was no more oil in the ECU
- Upon re-priming the system after the Injector replacement, they couldn't get the car to start
- Traced the issue back to the fuel pump, to find that it had been wired up back to front.
- Issue solved and back on the road from today
Very excited to have my pride and joy back - fitting a few miscellaneous bits and pieces this weekend so see some updates to my build thread next week. Have been told to keep my eye on the oil level to ensure it doesn't rise over the next few trips.
Post #798642 18th Oct 2019 2:28pm
jst
Reprimming the injectors? They took them out? Why?
How was the fuel pump wired up wrong go cause that fault? Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #798663 18th Oct 2019 5:44pm
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
td5 always check
3 fuel pump is working
2 crank sensor
1 relay isn't loose under seat lol
Thumbs Up Have fun be happy
Post #798667 18th Oct 2019 6:11pm
Mdm
im a bit confused the fuel pump has a plug on it.it only fits one way?
if you mean they put the fuel pipes on the wrong way round. not sure how it would run?
Post #798674 18th Oct 2019 6:54pm
othorton
From what I was told, there is a specific wiring order on the fuel pump. And the order was wrong. Rockingham was asked to replace the injector harness by the dealers I bought the car from and then after replacing the rocker cover they couldn’t get it to fire.
Long story short it was a fuel pump issue.
Hopefully the last issue for some time.
Post #798753 19th Oct 2019 10:37am
dorsetsmith
Post #798758 19th Oct 2019 10:54am
dorsetsmith
fuel pump socket can only be connected to one way only see ( bottem right hand of the connector in the pic )
fuel pump socket wiring pins modded in place
in order for pump motor wired wrong pump has to be removed and two spade connector reversed see top pump motor red and black wire and engine will not start as the two stages of the pump are working wrong around if fuel presser is below 1bar at the injections engine will not start
If wiring loom plug wire wrong Exclamation female connector have to be removed from the plug
They put the fuel pipes on the wrong way round. will not run as the two stages of the pump are working wrong around if fuel presser is below 1bar at the injections engine will not start
Post #798770 19th Oct 2019 12:46pm
dorsetsmith
Post #798800 19th Oct 2019 8:52pm
dorsetsmith
Post #798801 19th Oct 2019 8:54pm
dorsetsmith
Post #798802 19th Oct 2019 8:54pm
jst
so what your saying is its impossible for it to have run if the pump had been miswired. Cheers
James
110 XS Utility
90 Puma Hardtop
Post #798812 19th Oct 2019 10:49pm
othorton
Thanks very much for the detailed reply Dorset.
I appreciate the skepticism from you all and see it as one of the strongest aspects of this forum that people will call out the bull from mechanics attempting to 'have-over' people who are ignorant of the workings of the defender (like me).
In fairness, the issue appears sorted as I did another 30 miles in it yesterday and the engine didn't miss a beat. I wonder if it's possible that the pump had been wired incorrectly not at the pump end. Either way the work was carried out under warranty so I am not out of pocket. I suspect there might also be an aspect of dumbing down to make it easier for me to understand.
I will let you know if I have any update or if the problem rears its ugly head.
Post #798891 21st Oct 2019 9:20am
jst
Thumbs Up Cheers
James
110 XS Utility
90 Puma Hardtop
Post #798907 21st Oct 2019 12:19pm
Page 2 of 3 <123>
