![]() | Home > Td5 > TD5 Cut-Out |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2225 ![]() ![]() ![]() |
I would say dodgy / loose crank sensor wireing.
Had very similar issue recently |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 ![]() ![]() ![]() |
You say you've found some oil thats migrated all the way down the loom to the ECU end. So what about the join at the front of the rocker cover, I expect that is positively gushing and all sorts of shorting etc.
I would start with a rocker cover gasket and a Bearmach or better quality injector loom. Its a 5 min job with an 8mm socket as the only tool required. |
othorton Member Since: 22 Jul 2019 Location: London Posts: 104 ![]() ![]() ![]() |
Hi Both,
Thanks for your replies. We took the rocker cover off to take a look and see if there were any obvious issues with the injector connections. I certainly never noticed any evidence of oil "positively gushing and all sorts of shorting" at the front of the rocker cover. Admittedly I am new to Defender ownership, and having only ever owned German Hatchbacks which are majority electric I am not well versed in the TD5 Engine, however the Oil working its way down the injector loom is a seemingly common issue - many people change the injector harness as an annual service item. I will order the bearmach parts and see whether that solves the issue - thanks for the advice. If it occurs again after that replacement I will get it booked into my local indy to see if they can diagnose any issues. Oliver |
Seeing I’m at the car right now ...
If you have oil in the ecu it migrated from the rocker area. So I am shocked you have no signs of oil at the multi pin join here You did look in the connector yeah? ![]() Click image to enlarge |
I didn't look at the connector. Unfortunately I didn't know that it was a spot to look at until some more googling this morning whilst at work. I will take a look tomorrow but suspect that if there is oil in the ECU connector, there will be oil in the multi pin joint.
Do you recommend replacing the whole loom? Or just cleaning it out. I will get the rocker cover gasket and injector harness on order. Is it undrivable until that point - or would you expect it to be fine so long as what little oil might have worked its way up is cleaned out? Thanks, Oliver |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 677 ![]() ![]() ![]() |
The oil is not a real problem - for such a low voltages in car it is very good isolator. First try it with some diagnostic equipment like Nanocom. Before you start changing any parts. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3499 ![]() ![]() ![]() |
Had this a few times on Td5’s. Pop the red connector off onto the ECU under the drivers seat. You will see oil if so.
Basically requires the injector loom changing which is an easy DIY job. Put a little nick in the lowest point/bend in the loom casing near the ECU and give the oil somewhere to drip out. Clean the connector weekly for next few months and it will all be good again. 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
Thanks Family Mad,
Just to confirm - when you say you've had this before, are you referring to oil in the red connector, or the unexpected shut-off? Thanks, Oliver |
Hi,
Both. And they are linked. Started with rough running in a 90 I had. In a 110 i was driving from Scotland to London it was an out of the blue engine that stopped with no warning. 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
Not heard of oil in the plug causing total engine shut off before. Rough running yes but not total failure.
Easy to clean anyway but i would check the crank sensor wiring as well. Can cause these exact issues. |
Hi Bankz,
Thanks for the reply. I will take a look at the wiring, though in fairness I won't know what I'm looking for/at. From what I've read about the Crank Sensor, if this isn't working, the engine will fail and then not start. Each of the two times it happened, the engine was warm, and after 2 or 3 minutes it started up again without issue. Would a faulty sensor 'reset' after a couple of minutes of the ignition being off? In the meantime, I have ordered a new Injector harness and cam cover gasket, which I will replace as part of a service schedule. @Family Mad, I will clean out the pins in the ECU and cut the small hole you mentioned. Thanks, Oliver |
Not if the wiring is breaking a circuit. Connecting and disconecting due to vibration.
Like so - ![]() Click image to enlarge Its on the left hand side of the bellhousing on the side/top area. |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1657 ![]() ![]() |
i would get it plugged into a lr spec diagnostics system.
it can be many things. oil in the loom doesn't usually cause the issues you have had. wiring to crank position senor or the sensor itself followed by the ecu failing. ask me how i know. |
Thanks Mdm.
The OBD from the AA didn't show any faults, but I imagine it wouldn't be as good as a landrover specific diagnostic tool. Given you're the third person to mention the Crank sensor I will go down that avenue in my investigation. I know a good Indy up in Leicestershire and will book in there as soon as I can. In the meantime, is the defender still good to drive or would you steer clear (no pun intended)? The plan is to clean out the ECU of any potential oil anyway, and drive sympathetically until I've had someone look at it who actually knows what they're doing - assuming it's ok to drive. Otherwise I'll get it to the closest LR workshop down here in London. Thanks, Oliver |
