Home > Maintenance & Modifications > Galvanising
Galvanising
This one might be a bit vague with no definitive answer.
I have a fair few parts on my 90 that need galvanising and powder coating.
I've been looking at Wedge group Crediton, Devon.
I did contact them once regarding work but I can't remember what they said now I think they said they could do the lot in one sweep but I couldn't get that done for practical reasons at the time.
I'm aware that blasting is needed first, drilling prior to hot dipping etc and this plant can do powder coating too I believe.
Ideally I'd like to do a few bits at a time, as this is easier to courier and remove and re-fit or have spares for.
So far example I have the following;
FF shadow A bar.
Side steps
Rear quarters
NAS tow step
Exmoor tip up seat parts
Mantec roof bars
The two parts that are a bit of a pain to me are the A bar due to number plate, and I can get a spare bumper to solve that.
NAS tow step as I do need to tow but a couple of weeks isn't too much of an issue.
Without contacting them and becoming involved what would you be expecting to pay for blasting, possibly drilling.
Hot dip galvanising and powder coating?
Obviously I'd remove the chequer plate myself on a couple of items.
It would be easiest for me to courier say two pairs of items a time or similar unless I gather it all up but then it is a lot.
Has anyone else had anything similar recently, I would imagine others here have been in a similar scenario as it's better now than leave it too late as my steps have had it already. Rolling Eyes
Thoughts welcome. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #798565 17th Oct 2019 7:56pm
I've used Wedge in southamton (before they were in the "wedge" group IIRC)
It was for a chassis one time, then a chassis and some side rails, they came and collected once, and the other time I took it down there.
quite helpfull as I recall.
Back when I did it (nearly 10 years back for the last item), there was a minimum amount, so you'd probably be best to get it all together as one lump.
Yes, make sure vent holes are drilled... my current 110 chassis is an ex military armoured one, so has lots of extra plates welded onto it.... some of which are now slightly balloon shaped as I didn't reaise about how damn hot galvanising is... it just expanded the steel like it was rice paper.
Post #798569 17th Oct 2019 8:19pm
Mdm
we use pillar wedge near us and they are very good with a turn round od 7-21 days depending on how busy they are.
they have a min weight so it pays to get all y9ou items in to them at once.
as far as i know they don't galv used chassis any more.
our local one will not drill or work on any part that you drop off but will refuse to dip it if it doesn't have enough suitable sized holes.
price wise it varies so much on whats dipped. eg we had some axles done and after blasting de-greasing and galv we then had to spent hours drilling and tapping out the holes.
you can leave bolts in to keep the threads clean but they will often snap when you try to remove them.
Post #798608 18th Oct 2019 8:32am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I like that, I bought two axles to fix up and replace mine and I'm thinking of Galv 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #798627 18th Oct 2019 11:17am
Good to hear. I know they wanted to know weight last time and qty of items.
That was a stumbling block because I couldn’t do that, as didn’t have temporary spare parts to fit at that time.
I think they said 6mm holes in enclosed tubing or box section to prevent any explosions!
And as mentioned any threaded holes etc need re-tapping etc too.
In my case other than roof bars that isn’t an issue.
I’m thinking for my items about £100 - £140 but I really have no idea. Better that than losing one items to corrosion though.
Maintenance to keep it at bay is a real pain.
I don’t mind the chassis but the rest is damned awkward to keep on top of. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #798629 18th Oct 2019 11:29am
Remember that the cost of galvanising is usually based on the difference in weight before and after (ie the weight of added zinc) and bear this in mind when drilling your holes. If you have something like a rock slider, and the holes allows the tube to fill with with zinc and not drain, expect to pay a very considerable price for the hundredweight or so of zinc that has taken residence in your tube!
Post #798633 18th Oct 2019 11:59am
Indeed, I think that’s why they specify a certain hole size minimum to drill. And then bearing in mind structural integrity.
Most tubing is open with caps, but not all tubing and box section.
I know they said it was critically important and weight before being quoted for. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #798635 18th Oct 2019 12:44pm
Mdm
i think the min weight near us is 100kg but we're always over that.
spend a good sum on new drill bits and decent tap and dies and you will be fine plus some nice cutting oil will keep the drill bits sharper longer
Post #798637 18th Oct 2019 12:54pm
Horneteer
United Kingdom 1986 Defender 90 200 Tdi SW Firenze Red
I would recommend Cardiff Galvanisers any day of the week, but would not go near Crediton with a barge pole ......
I had bad reports about Crediton, but nothing but recommends for Cardiff, based on the company that I work for and colleagues and neighbours that I have spoken to.
As soon as Crediton know they are Land Rover parts the price rockets, the bulkhead on its own was quoted at £150+VAT, with £10+VAT for each additional item. So all the bits I had to get done was going to cost me close to £300 plus VAT plus a signed disclaimer that if they bent it, it would be nothing to do with them. One friend had his defender roof rack galvanised and was quoted a price per kilo which then more than trebled after it had been done because "its from a Land Rover". My boss had his garden railings bent because they picked them up by the skinny spindles rather than the much stronger top or bottom rails. The finish on the galvanising we have done at work looks like its full of grit, ideal it you want a non skid surface but not if you want to paint it.
Cardiff on the other hand couldn't be more helpful and charged a flat fee of £80+VAT for the first 100kg and 80p+VAT per kg after that (prices as of April 2017). Bulkheads were no problem as "we do them all the time and don't have any issues". They could do the whole lot in a day providing it was ready to be galvanised and didn't need any basting or further preparation.
The job was booked in for a friday and I had to drop the items off soon after they opened at 8:00 am. The preceeding week was spent with the garage converted into a blast booth to make sure all was ready, the car was loaded with the bulkhead, 2 door frames, bonnet frame, cooling pack frame, and all of the associated mounting brackets. I left Cornwall at 5am for the drive to Cardiff, booked the items in and spent a day sightseeing including visiting Cardiff Castle. I rang just after 1 to get a progress report and was told "It's all done and waiting for you". At 68kg completed you can work out how much it cost, even when you take into account the day out in Cardiff and the extra fuel cost, it was still cheaper than going to Crediton. Did it warp when it was galvanised? No, it was as straight as it was when I delivered it.
If I need to get anything else galvanised, it'll be another trip to Wales.
For powder coating, I would use Hadley Powder Coatings in Plymouth. They can powder coat, shot blast and wet paint. My A bar still looks like new after 5 years, satin black powder over blasted steel (no galvanise).
Hope that helps
Paul
Post #798649 18th Oct 2019 3:07pm
Interesting reading, thank you all. Thumbs Up
A wealth of knowledge as usual, which always proves useful indeed. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #798666 18th Oct 2019 5:08pm
LR Sam
Slightly different question - would the guys who have galvanised parts before recommend it? I have a new Series 3 chassis - the standard answer is to galvanise it to make it last, is there anything else out there that does a good job that isn't galvanising? My hesitation to galv is getting it to a galvaniser, the cost and the fact that I will be welding engine mounts on at a rolling chassis stage, then having to strip back to chassis and send for galvansing. If I could use something that had similar rust inhibiter properties that could be done here instead? If everyone says Galv is the best way, that is what I shall do.
Post #800352 1st Nov 2019 4:18pm
Silvertoolbox
I did all body cappings, bumper, wheel brace and starting handle. £25 pounds min order (in 1984...) Wink
Land-Rover equivalent of chrome plating!
Certainly recommend it... Thumbs Up Ex scottish & southern 110 Td5 van (shed) with PTO driven winch (L-R special vehicles)
Before that, Disco 1, Freelander 1, 26105382 80" with a 1600cc (not much slower)
Post #800371 1st Nov 2019 5:31pm
Laurie
Have you tried Medway Galvanising?
They have jigs for most LR parts.
https://www.hsholdings.co.uk/our-companies...ompany-ltd
Post #800427 1st Nov 2019 11:15pm
familymad
Love the knowledge base on this forum. Top info always freely provided Thumbs Up 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #800451 2nd Nov 2019 9:41am
