Home > My Defender > What Did You Do In Your Defender Today |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 745 |
Double post
17th Oct 2019 8:04am |
On mine the bolts holding the tub on that when tighten compress the foam strip were loose. One was totally missing in the middle. Maybe torque them down a bit. I would get a pressure washer or hose pipe on the outside of it whilst someone sits inside. I went over all of my seams with Tiger Seal including running it down the foam strips you mentioned. Have a look around where the rear lights, indicators bolt through. |
17th Oct 2019 8:08am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16884 |
^^^ Use an assistant with a hose pipe, it is just about the only way to find leaks like this. I wouldn't use a pressure washer since this is likely for force water in in places that don't actually leak in rain (I tend to use a hose with one of those sprinkler nozzles for watering plants to mimic heavy rain).
17th Oct 2019 9:03am |
DG123 Member Since: 29 Aug 2015 Location: North West Posts: 133 |
Cheers blackwolf and boxoftricks. I’ll get the hose out later when my willing assistant returns from school
Might just run sealant down the foam strip anyway as it does look the most likely candidate. 2012 110 XS SW Orkney Grey 2003 D2 Td5 Black [SOLD] |
17th Oct 2019 9:07am |
Hi barneyboy, I checked the bolts and they seemed OK.
I’m not sure whether the water’s coming in through the wheel arch whilst driving or just leaking from rain. The water does look pretty clean though, so I suspect rain and we have had an awful lot lately. Bizarrely, just prior to this the main leak was in the passenger footwell and I’ve just had a new front door seal delivered to try and fix that one. Like many things with the Defender the footwell leak was frustratingly intermittent - went for months dry as a bone and just when you thought it was sorted it’d be back with a deluge I’ll have to get the hose out 2012 110 XS SW Orkney Grey 2003 D2 Td5 Black [SOLD] |
17th Oct 2019 11:36am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2592 |
Had the rear electrical wiring re-done & upgraded (long overdue): they ripped out the old wiring which ran undernead the drawer system, and re-routed it outside on top of the chassis.
Also added a new rear-view camera & mirror and new Bosch AeroTwin wiper blades (highly recommend these @ R315 a pair). It cost a pretty packet, but as usual, top job by Mette's Auto Electrical! Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
17th Oct 2019 3:59pm |
Barneyboy Member Since: 19 Nov 2014 Location: Oxfordshire Posts: 1583 |
Hi DG123 I know it’s a pain but I’m sure with a bit of perseverance you will get to the bottom of it, Paul |
18th Oct 2019 6:39am |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1333 |
Click image to enlarge Yesterday went and picked up this little gem. |
19th Oct 2019 6:30am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
Very nice, what's the plan? James
19th Oct 2019 7:59am |
Just do a few jobs on it, get it MOT’d.
My keep it as a work horse whilst I do my house up but seems a shame to ruin a 200tdi D1 as they’re a bit scarce now. Engine is super sweet as is gearbox. Done 120k and last owner 15 years. |
19th Oct 2019 5:42pm |
James
19th Oct 2019 5:48pm |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1805 |
Like that AJC. I have a bit of a soft spot for the discovery having had a K plate 200tdi as a bit of a green lane toy about 12 years ago. Was pretty much unstoppable out of the box. Shame the ones in my price range now are all snotters.
Still haven't got the 110 back so had to do an ikea run in the courtesy disco sport. Doesn't matter you drive there it's never a pleasant experience 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
19th Oct 2019 9:03pm |
That trailer looks as though it's barely coping! |
19th Oct 2019 10:27pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19579 |
My 90 passed it’s MOT with a clean sweep Friday.
Glad that is over, as I can get on with other jobs now. Seems only like yesterday I had the last. It’s worrying how time flys it really is! Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
20th Oct 2019 11:42am |
