Home > Puma (Tdci) > Electrical issue |
HardCharger Member Since: 03 Mar 2013 Location: Manila, SFO, Amsterdam Posts: 678 |
Maybe your battery has not had time to recover / charge up sufficiently? If you have a battery charger, charge up the battery as the trips you are doing may not be long enough to fully charge the battery back to optimal operating levels.
You mentioned a loose earth connection at the battery, the post tends to deform. What I do is to put a copper sleeve around the post before putting the clamp on to ensure proper and snug contact. For the positive post, I get a strip of lead, pound it flat and make a sleeve for the positive post as insurance. Don't forget about the sleeves as you can re-use them when you replace batteries in the future. If problems persist after the battery has been restored to optimal operating levels, maybe it's time for a new ignition switch. Let us know what you find out. |
17th Oct 2019 2:32am |
Tankcr2 Member Since: 16 Oct 2019 Location: Bloemfontein Posts: 3 |
Thanx. Will get it checked out today. Do battery test. Charge, and get ignition switch checked. Keep you posted
17th Oct 2019 3:39am |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
First and most important thing to check is the loom running across the engine bay, it has been known to rub on the engine in various places and cause issues eventually shorting out.
Also check earth straps underneath aren't loose (i.e. other end of negative battery cable) as this could have the same result. I'd also be checking all relays under driver seat and if you can check alternator connections. Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
17th Oct 2019 6:53pm |
I had it checked today by the indy. Couldnt find anything apart from a doggy relay under driver seat. I took it an drove a few place before heading home. 45 mins later i had it again. This time it had same symptoms but took a goo 5 mins before i was able to get power on by multiple attempts to start with no power coming on when key is turned in ignition. This happened only when i had the aircon on. I turn the aircon off and drove 13 km. The took my phone when i was near my home, and switched the aircon on. Few seconds later its same occurrence. Its as if you turn off the ignition completely whilst driving, but without locking the steering.
I waited for almost 30 mins . Truing to get power to the ignitio to stsrt. Headlihts hazards everything works. As if you the ignition is turn off. I towed her home. And still unable to get live On the dash with the ignition turuning. Nothing. Seems like the ignition has no contact. Do my verdict is the the ignition switch has gone |
17th Oct 2019 7:28pm |
That sounds very much like failure of the switch on the end of the ignition barrel. There's been a few reports on here of failures resulting intermittent starting exactly as you describe. There are several threads on the subject but this one is probably one of the most detailed:
https://www.defender2.net/forum/topic51335...ion+switch Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
17th Oct 2019 9:17pm |
