Home > Wheels & Tyres > Wolf at my door... |
Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 226 |
A quick question to you LRA, and indeed JTP if i may.
From looking at the wheel nuts which do look great, You have decided to retain the original studs. Did you look at replacing with the extended studs, I too have a set which i intend to use over the winter months and had hope to rotate either set of wheels (Wolfs or Sawtooth) without any great effort. |
12th Sep 2019 4:48pm |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
I wondered about the studs too, but it has been covered on here before, and as the army use the standard studs, I was happy to stick with them.
Apparently you do need to tighten the nuts more though. I've no idea of the torque figure but I just extended my, er, extending wheel nut spanner and gave them a bit extra. They haven't come loose so far and of course any threads outside the nuts aren't actually doing much. |
12th Sep 2019 4:56pm |
No, I'll retain the original wheel studs. LR didn't change them for the vehicles sold with these wheels from new, so I don't see any point. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 15th Sep 2019 10:36pm. Edited 2 times in total |
12th Sep 2019 4:59pm |
Thanks for that LRA, The original pattern it is so
12th Sep 2019 5:40pm |
So, got them fitted today
Click image to enlarge Click image to enlarge Thanks to those that suggested anthracite - I'm very pleased with the way they've come out. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
16th Sep 2019 10:56pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3618 |
They look excellent
17th Sep 2019 7:10am |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2055 |
spot on.......
17th Sep 2019 9:37am |
I like these very much, coupled with the capped wheel nuts, they look really smart.
17th Sep 2019 9:31pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1782 |
I see these are Matt black as supplied, so can I ask Darren, if the quality of finish was good enough to leave - assuming you wanted Matt black of course? Thanks Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top |
11th Oct 2019 5:45pm |
They looked ok but I wouldn't swear to it as a good final finish. I didn't look too closely, I'm afraid, as I always intended to have them painted. Darren
11th Oct 2019 8:37pm |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 |
Not wanting to blow smoke up your arse but that is the cleanest, straightest, rustless Defender I've ever seen, and the wheels looks suit the overall look. Well done on both counts
11th Oct 2019 9:40pm |
That's very kind. Thanks very much Darren
12th Oct 2019 8:06am |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1190 |
The only colour a Defender's tyre should be:
Click image to enlarge Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
12th Oct 2019 8:20pm |
Torque for genuine HD Wolf wheels with steel nuts is 170 Nm. Genuine alloys require 133 Nm. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
12th Oct 2019 8:40pm |
