![]() | Home > Technical > Stuck injector |
| Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674
On older diesels you could disconnect the diesel feed, loosen the retaining clamp and blip the engine on the starter. However I’m not sure if the puma would be okay to do this, I assume there should be a dedicated puller/slide hammer as like the TD5.
Sorry not much help, you could try bolting it all together and running it up to temp and then try removal. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
| All times are GMT |
