![]() | Home > Td5 > Strange noise from underneath |
isy02 Member Since: 20 Apr 2015 Location: inverclyde Posts: 10 ![]() ![]() ![]() |
Hi Roddy
Had similar on my puma recently although at a slightly higher speed,turned out to be loose exhaust heat shield. |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 687 ![]() ![]() ![]() |
I had similar noise -turned out the lower bolt on a bracket for the DPF had worked loose.
Only found it after removing all the heat shields first as a method of elimination. It might just be a loose bolt on the exhaust. |
Another place to check are the front brake stone guards as they can make this kind of noise. At faster speeds the air moving past holds them in place and stops the noise. To begin with just pinch the retaining peg closed a tad and it will stop the noise.
T140 Member Since: 15 Mar 2016 Location: Ayrshire Posts: 180 ![]() ![]() ![]() |
I had a similar noise on a previous car it turned out to be a loose dirt shield ( if that's the term for it ) on one of the transfer box output shafts, a punch and a hammer fixed it. nobody is perfect but being Scottish is a start
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 605 ![]() ![]() |
I have had something similar going on for over 18 months. A metallic jingling sound at about 1550 rpm. Mine is rpm dependant in 4th 5th and 6th under load. I have done everything to find it bar running it in gear on a lift. I’ve searched every nook and cranny and tweaked or moved every heat shield. I’ve used a go pro under the car to film various components to see if they are harmonically vibrating. I will be watching with interest to see if this is resolved.
I’m also going to remove my exhaust soon as the truck has Had a new head in the past and i have a small suspicion something has been dropped/ left inside some part of the exhaust whilst it has been off |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
Thanks all for the replies, definitely stuff to look out for when it’s in the garage (hopefully) next week. If there is anything found I’ll definitely post on here. As I said, it doesn’t sound that serious, but it’s just the annoyance/embarrassment factor of driving along the road and tinkling away. Fingers crossed it’s just something that needs a wee tighten up.
As Siwynne has mentioned, I had thought about attaching an action camera to the underneath to watch what was going on, but as it’s due into the garage anyway soon then this might be my fall back option ![]() |
Well the motor was in last week for it’s service, free off the difflock and replace a weeping N/S rear oil seal. I asked the lads to have a good look for anything loose which they duly did. They never found anything untoward but as part of the service they greased up the prop shafts. The noise has disappeared for now (hopefully permanently) with nothing obvious found. Maybe it was a dry joint on a prop shaft, I don’t know. I know this is of no use to anyone who might have a similar problem, but these are my findings.
DOH!!!!!
After a decent run at the weekend -150+miles - I can confirm my ringing noise is back. Seems quieter in the cold mornings, getting more noticeable as things heat up. Back to the drawing board then ![]() |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1782 ![]() ![]() ![]() |
Mine has a similar noise, having gone through it and spoken to a couple of others, I've come to the conclusion it's wear in the transfer box. Quite possibly the bushing which supports the intermediate shaft.
Fresh TBox oil tends to quieten it down for a bit. The noise has been there and not gotten worse for 30k though! |
jimonut Member Since: 02 Jul 2019 Location: somerset Posts: 11 ![]() ![]() |
mine was making a similar noise , ended up being the transmission brake .Put the transfer box in neutral and the car in gear and rev see if the noise is there and then pull up the handbrake and see if it disapears
